Author Topic: Fuel Leak from Throttle Shaft  (Read 3067 times)
June 05, 2009, 03:40:56 am
Frank06
  • 14
« on: June 05, 2009, 03:40:56 am »
'86 Jetta 1.6.  Is there any information on how to change this seal?  Fuel is being pushed up the shaft (on top of the pump) and dripping down pretty regularly.  It sometimes goes away but seems more consistent now.  I'd appreciate any advice, opinions, etc.  Is this the best place to post this question?  I've been reading old posts and have learned a lot but haven't run across this particular issue yet.
TIA
Reply #1June 05, 2009, 12:40:45 pm
blackdogvan
  • 574
Re: Fuel Leak from Throttle Shaft
« Reply #1 on: June 05, 2009, 12:40:45 pm »
I'm no help but good to see your name over here! You should post some of your head rebuild photos & get some vendor status here!!
1991 Vanagon 1.9 mTDI
Reply #2June 05, 2009, 08:41:17 pm
Frank06
  • 14
« Reply #2 on: June 05, 2009, 08:41:17 pm »
Thanks for the props but I think you're confusing me with someone who actually knows what they're doing!  Sorry, wrong person.   :-X
Reply #3June 05, 2009, 09:05:55 pm
madrogers
  • 165
« Reply #3 on: June 05, 2009, 09:05:55 pm »
i bought the seal kit from a local turbo shop for 18.00 can. it had all the o-rings and ft seal . the pump was for a 95 1.9 aaz , i was able to pop the top off and remove the shaft and rpl the o-ring the shaft has to come out to do it on this pump. just slowly lift the cover off and look what / how it comes apart  mine was in the vice/bench  it would be much harder on the car.
my expereance. PS they told me that if the shaft bushing was worn it has to be epoxed glued in to rpl it.
mark
83 CADDY 1.6 TD WINTER
83 CADDY 1.9 AAZ SUMMER
Reply #4June 05, 2009, 09:15:31 pm
blackdogvan
  • 574
« Reply #4 on: June 05, 2009, 09:15:31 pm »
Ok that makes sense, I was wondering why frank was posting that question in the tdi section...
FYI frank06 is a major contributor over at tdiclub
Reply #5June 06, 2009, 03:47:20 am
Frank06
  • 14
« Reply #5 on: June 06, 2009, 03:47:20 am »
Aha!  Maybe that explains what happens when I disappear for weeks on end and wake up in strange cities...
p.s.: thanks for the info on tdiclub
