Author Topic: 120 amp alternator  (Read 5059 times)
June 03, 2009, 08:36:22 pm
dieselsmoke
120 amp alternator
« on: June 03, 2009, 08:36:22 pm »
I have my 1.9 aaz td engine and I was looking at getting my 90 amp alternator rebuilt and have the clutched pulley put on it. Before I do the rebuild, does a 120 amp alternator bolt directly on or is there modifications needed???
Reply #1June 04, 2009, 05:14:31 pm
allsierra123
Re: 120 amp alternator
« Reply #1 on: June 04, 2009, 05:14:31 pm »
its a direct swap but with no w terminal for the tach.
Reply #2June 04, 2009, 05:40:26 pm
« Reply #2 on: June 04, 2009, 05:40:26 pm »
there is a way to make your own W terminal by opening the Alt and adding a diode or something.. like that..
Search for it on here.. someone wrote about it. or google adding W terminal to alternator or something.
Reply #3June 05, 2009, 06:25:22 am
arb
« Reply #3 on: June 05, 2009, 06:25:22 am »
Easy - the W is a lead between one of the coils and the bridge rectifier (diode).
Reply #4June 05, 2009, 06:58:48 am
« Reply #4 on: June 05, 2009, 06:58:48 am »
Like so:
Reply #5June 05, 2009, 05:59:29 pm
James8485
  • 223
« Reply #5 on: June 05, 2009, 05:59:29 pm »
i am running a 120 amp Alt. on my AAZ with a working tach....
i got the alt. from a VR6 Corrado its a 120 amp i switched the pully and its direct bolt on
works great!
---------James--------
Reply #6June 05, 2009, 07:41:15 pm
dieselsmoke
« Reply #6 on: June 05, 2009, 07:41:15 pm »
perfect. My only other question is, part of the reason I want to go this route is for the clutched pulley. Will the clutched pulley work and line up properly??
Reply #7June 09, 2009, 01:14:33 am
fukengruven1982
  • 35
« Reply #7 on: June 09, 2009, 01:14:33 am »
I have a 120 amp alternator on my aaz motor from a 98 golf with an aba motor....has provisions for w terminal....not sure what else to tell you...
Reply #8October 04, 2013, 10:37:14 pm
JimEG
  • 32
« Reply #8 on: October 04, 2013, 10:37:14 pm »
Were your lower amp core returns accepted for the 120 amp?
Reply #9October 05, 2013, 01:55:43 am
Toby
  • 728
« Reply #9 on: October 05, 2013, 01:55:43 am »
Just wait a week or two before returning the core. They won't remember won't came in the box. Most of the time they pitch the boxes and ALL cores go into the same 55 gallon drum in the back.
Reply #10October 05, 2013, 05:19:44 am
DogDiesel
  • 210
« Reply #10 on: October 05, 2013, 05:19:44 am »
Will the clutched pulley on AAZ alternators and "w terminal" driven tachometers give you RPM drop on deceleration?
Wayne
Reply #11October 05, 2013, 06:00:59 am
« Reply #11 on: October 05, 2013, 06:00:59 am »
no... you do not see pully in tach...
Reply #12October 05, 2013, 06:45:30 am
bbob203
  • 1789
« Reply #12 on: October 05, 2013, 06:45:30 am »
90% of the time no but mine has done funny things once or twice.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
