Author Topic: mechanical injected tdi running  (Read 16212 times)
Reply #15September 24, 2005, 04:55:46 pm
tammons
  • 5
« Reply #15 on: September 24, 2005, 04:55:46 pm »
So is that pump/shaft etc. strong enough to handle DI pressures. I have been kindof thinking about using a stock VW TDI marine pump, but I have yet to locate one.
Reply #16September 27, 2005, 08:30:37 pm
scopefrfd
  • 289
« Reply #16 on: September 27, 2005, 08:30:37 pm »
Quote from: "tammons"
The pump came from a TDI engine.  In europe they used mechanical pumps on tdi cars and trucks in the early going.
Reply #17September 30, 2005, 04:41:58 pm
RabbitGTDguy
  • 1274
« Reply #17 on: September 30, 2005, 04:41:58 pm »
TDI Marine pumps are very expensive, and very hard to come by. From what I've been able to find out about them as well they are nothing really more than the same pump that was run on the late IDI 1.9AAZ motor, turned full tilt...
scopefrfd :Congrats on your mechanical TDI! I'm working on mine now and I'm glad to say that my pump choice having been able to have a friend test it is going to BE AWESOME :)
Joe
1972 VW Westfalia
Reply #18October 07, 2005, 05:02:30 am
jos_br
  • 8
« Reply #18 on: October 07, 2005, 05:02:30 am »
I drive a VW Caddy 1 with a mechanical pump (12mm). I use the intercooler from a Mercedes Sprinter and special nozzles (Frattelli 0,260mm). Specs.208hp and 480nm. The brakes i use are 312mm. (Audi TT)
Jos.
Reply #19October 07, 2005, 07:44:33 am
VWRacer
  • 649
« Reply #19 on: October 07, 2005, 07:44:33 am »
Those are very impressive numbers, Jos. Can you tell us more info about your Caddy and show us some pics? Where are you located?
Stan
C-Sports Racer
Reply #20October 07, 2005, 08:28:18 am
jos_br
  • 8
« Reply #20 on: October 07, 2005, 08:28:18 am »
I am located in Holland and it takes my 4 years to get those specs out of this engine.
Jos.
Reply #21October 07, 2005, 08:30:02 am
jos_br
  • 8
« Reply #21 on: October 07, 2005, 08:30:02 am »
Look here.http://vwcaddyforum.com/showthread.php?t=6054
Jos.
(The blue caddy).
Reply #22October 07, 2005, 08:44:43 am
VWRacer
  • 649
« Reply #22 on: October 07, 2005, 08:44:43 am »
Holy cow!  :lol:
A caddy bed grafted onto a Jetta...how trick is that!?  :wink:
Jos, are the engine internals stock? Are you still running a K24 , or is the 208 hp with the new roller bearing turbo?
Please tell us more.
Very cool!  8)
Stan
C-Sports Racer
Reply #23October 07, 2005, 09:38:16 am
jos_br
  • 8
« Reply #23 on: October 07, 2005, 09:38:16 am »
The car is build out of two cars,a Jetta and a caddy so the car is 22cm longer than usual. The engine was running with the k24 208hp and is now running with a adjusted rollerbearing turbo but the outlet is not good, so it must be adjusted agian.
Jos.
Reply #24October 07, 2005, 11:03:23 am
VWRacer
  • 649
« Reply #24 on: October 07, 2005, 11:03:23 am »
208 hp on a K24...very cool!  :D
Are the engine internals (pistons, rods, etc) stock or stronger aftermarket pieces?
Stan
C-Sports Racer
Reply #25October 07, 2005, 12:17:43 pm
jos_br
  • 8
« Reply #25 on: October 07, 2005, 12:17:43 pm »
The onley things i've changed is a lowered compression and i have used other bearings (not piston). The k24 was also adjusted (stronger bearing) but not good enough, i have "used" four of them............
Jos.
Reply #26October 09, 2005, 04:14:31 pm
RabbitGTDguy
  • 1274
« Reply #26 on: October 09, 2005, 04:14:31 pm »
Quote from: "jos_br"
Jos.
(The blue caddy).
MMM.... that looks nice. Most impressed with the bodywork that was done. To the unknowing, probably even "knowledgeable" VW eye I doubt you could tell the differences in the length, etc. At least from the pics I see... Very nice job Jos.
1972 VW Westfalia
Reply #27October 09, 2005, 05:10:13 pm
« Reply #27 on: October 09, 2005, 05:10:13 pm »
Wow, beautiful Caddy!  :)  Really nice numbers too.  :)  Do you by chance have a dyno plot?  If not, do you know roughly what RPM peak hp is?  There is not a lot of people out there with hopped-up mechanical TDI's like yours so I'd like to know what the power curves are like.  Thanks and great work!
84 Scirocco 8v
00 Camaro L36 M49
Reply #28November 15, 2005, 10:40:42 pm
jos_br
  • 8
« Reply #28 on: November 15, 2005, 10:40:42 pm »
From another site, it's my car.
http://www.tdiclub.nl/topic.asp?whichpage=1&TOPIC_ID=13477&FORUM_ID=4&CAT_ID=2&Forum_Title=Motorisch+tunen&Topic_Title=Vermogen+meten+op+rollenbank
Also some dyno plots from another car we have tuned. I'm not satisfied with the turbo and i will try to make some adjusments to the feulpump.
Jos.
