Fixmyvw.com
Author Topic: Audi 5000 IP  (Read 2780 times)
May 29, 2009, 08:32:26 am
dieselherb1
  • 354
Audi 5000 IP
« on: May 29, 2009, 08:32:26 am »
Can a Audi 5000 IP be used as a replacement for a TDI pump on a 1Z?
Reply #1May 29, 2009, 11:58:29 am
Re: Audi 5000 IP
« Reply #1 on: May 29, 2009, 11:58:29 am »
you would need a 10mm head or larger for the car to have decent power.  check the for sale section.  there is an 11mm head for sale.  i'm pretty sure it bolts right onto the audi 5k pump, but could be wrong.  AFAIK the 5 cyl and 4 cyl pump bodies are the same.
Reply #2May 29, 2009, 08:24:29 pm
Giles@PerformanceDiesel
  • 222
    • http://www.performancediesel.ca
Re: Audi 5000 IP
« Reply #2 on: May 29, 2009, 08:24:29 pm »
No the audi pump turns opposite rotation to the VW pumps.
there is nothing you can use on the vw pump from the Audi
Giles
Reply #3May 29, 2009, 09:58:16 pm
Re: Audi 5000 IP
« Reply #3 on: May 29, 2009, 09:58:16 pm »
Giles
ah... are the vw 5 cyl like that too?
Reply #4May 30, 2009, 04:31:39 am
MJF
  • 581
Re: Audi 5000 IP
« Reply #4 on: May 30, 2009, 04:31:39 am »
Giles
Same engines.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #5May 30, 2009, 11:56:18 am
Re: Audi 5000 IP
« Reply #5 on: May 30, 2009, 11:56:18 am »
Giles
Same engines.
ya i just remembered  ;D too bad :(
Fixmyvw.com
