Fixmyvw.com
Author Topic: tdi identification  (Read 6323 times)
May 24, 2009, 02:01:23 pm
13mmwrench
tdi identification
« on: May 24, 2009, 02:01:23 pm »
ok so i bought a tdi motor for a swap into one of my corrados  and was told it is a 1z motor out of a 98 jetta but the someone washed the sticker off of the top cover  so i am not fully sure what motor it is and i need to find a harness and computer for it.  it has a ko3 turbo and i thought that the 1z motors came with the garret gt15?  any help would be appreciated
Reply #1May 24, 2009, 03:25:48 pm
diesel smoke
  • 209
Re: tdi identification
« Reply #1 on: May 24, 2009, 03:25:48 pm »
A picture would be best, but I think the '98 came with a ALH TDI engine.
'99.5 Bora TDI
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
Reply #2May 24, 2009, 04:05:21 pm
« Reply #2 on: May 24, 2009, 04:05:21 pm »
1Z came in the 96/97 passat TDI (and maybe others) and the AHU came in the '98 jetta's, and some 99's mid year before the mk4's which had the ALH.
so it should be an AHU which is very similar to an aaz if not identical other than the head and crank sensor.
Reply #3May 25, 2009, 03:10:58 am
13mmwrench
« Reply #3 on: May 25, 2009, 03:10:58 am »
i will get a few pictures up in a day or two.  i'm new to tdi motors  but have plenty of experience with vag products     thanks for the help
Reply #4May 25, 2009, 08:59:13 pm
13mmwrench
« Reply #4 on: May 25, 2009, 08:59:13 pm »
they are camera phone pictures sorry
Reply #5May 26, 2009, 09:00:31 am
« Reply #5 on: May 26, 2009, 09:00:31 am »
thats a nice complete engine! definitely AHU.  probably the first thing you should do is remove the intake and have it cleaned, then delete the EGR using a block off plate.
Reply #6May 26, 2009, 01:35:25 pm
snakemaster
  • 405
« Reply #6 on: May 26, 2009, 01:35:25 pm »
how can you tell its a AHU , is it cos its got ribs on the injection pump , looks like a 1Z to me  but i do beleave the AHU lookes like the 1Z
Reply #7May 26, 2009, 10:10:14 pm
13mmwrench
« Reply #7 on: May 26, 2009, 10:10:14 pm »
anything i can take a picture of or look at to help make sure its an AHU?    oh and i already cleaned the intake  good old oven cleaner!
Reply #8May 27, 2009, 01:52:39 pm
« Reply #8 on: May 27, 2009, 01:52:39 pm »
the jetta's never came with a 1Z AFAIK.  in NA anyways...
i bet you could probably set an oven to 'clean' with the intake inside... might smoke a lot though  :)
« Last Edit: May 27, 2009, 01:54:20 pm by jtanguay »
Reply #9May 27, 2009, 11:21:19 pm
diesel smoke
  • 209
« Reply #9 on: May 27, 2009, 11:21:19 pm »
The best way that people use to clean the intakes is using fire. :o Use a propane torch and some compressed air. JUST BE CAREFUL!! When it doesn't burn anymore, use a pressure washer to blast out the rest of the carbon.
http://www.youtube.com/watch?v=oet4qWeZuYA
That reminds me, I need to clean the one on my TDI. I blocked off the EGR about a year ago, just never cleaned the intake.  :-\
'99.5 Bora TDI
'88 Fox Coupe
'85 Mercedes 300SD
Reply #10May 27, 2009, 11:24:51 pm
13mmwrench
« Reply #10 on: May 27, 2009, 11:24:51 pm »
well thanks for everyones help  now i just need to find a harness and pedal assembly for it
Reply #11May 28, 2009, 09:38:51 am
« Reply #11 on: May 28, 2009, 09:38:51 am »
be sure to get the pedal assembly for that type of car with AHU engine.  i've heard that some pedals have a reversed signal and will not work.  maybe someone who knows more about this can shed some light?
Reply #12May 28, 2009, 09:37:18 pm
13mmwrench
« Reply #12 on: May 28, 2009, 09:37:18 pm »
yeah if anyone knows what year range and application of the ahu  the harness and pedal assembly will work off of or maybe know of a lead on all the stuff that would be appreciated
Reply #13May 29, 2009, 08:21:28 am
Spulen81
  • 103
« Reply #13 on: May 29, 2009, 08:21:28 am »
You can use a pedal cluster from a A3 or B4 from 96-98.  If you are doing the swap in a MK2 chassis use the B4 cluster, its a straight bolt in.  The A3 cluster will only bolt into a A3.
You can run a AHU or 1Z on a A3 or B4 harness but the A3 ecu seems to be better.
'86 4Runner TDI SOLD
'91 GTI - TDI converted
Reply #14May 29, 2009, 10:21:22 pm
13mmwrench
« Reply #14 on: May 29, 2009, 10:21:22 pm »
thanks thats allot of help  i think i might have found a line on a harness and pedal assembly
S-PAutomotive.com
