Author Topic: Test Specifications: Distribtor-type Fuel-injection Pumps  (Read 8728 times)
May 23, 2009, 01:45:20 pm
Powered by Spearco
  • 1203
« on: May 23, 2009, 01:45:20 pm »
Got this from the diesel shop. Hope it helps.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #1November 07, 2009, 09:59:15 am
smutts
  • 720
    ClackClackClackClackClack
Re: Test Specifications: Distribtor-type Fuel-injection Pumps
« Reply #1 on: November 07, 2009, 09:59:15 am »
Ooh! I like this very much, well snaffled! 8)
That transfer pressure figure of 4.6 to 5.2 bar (66.7 to 75.4 psi) at 3000rpm engine is going to be very useful. ;D
Reply #2November 08, 2009, 08:33:41 pm
foxracer1
  • 991
« Reply #2 on: November 08, 2009, 08:33:41 pm »
Sweet Now i need a pump bench. I wish i could just have one avail to use. I could play with so much and it would no longer be guess work.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #3October 12, 2011, 08:36:52 am
« Reply #3 on: October 12, 2011, 08:36:52 am »
so how would you get the pressure curve of the yellow dot?  you would need the regulator from it with the matching advance spring?
Reply #4October 12, 2011, 08:24:31 pm
Powered by Spearco
  • 1203
« Reply #4 on: October 12, 2011, 08:24:31 pm »
I don't know but I can get more info on that.
'13 Golf R:. Tuned
'98 Puch G320
Reply #5October 13, 2011, 07:45:23 am
« Reply #5 on: October 13, 2011, 07:45:23 am »
yes, im sure thats how you would do it..
but i dont think i would want a 1.5 advance curve.. they are like, all advanced way too soon in my opinion..
why not use the stock advance setup so you actually have some advance left up top?
Reply #6October 13, 2011, 11:49:25 am
« Reply #6 on: October 13, 2011, 11:49:25 am »
As long as the total advance is the same it wouldn't make a difference at high rpm. You would have more marbles at lower rpm though.
