Author Topic: Camshaft seal is leaking???  (Read 4408 times)
May 22, 2009, 03:43:55 pm
katakura silk
  • 92
« on: May 22, 2009, 03:43:55 pm »
Hello, guys! Glad to be back! Once again I have a question for the masses.
My recently re-built head is leaking oil from the Camshaft seal...
My question is should I take the time to pull the Cshaft and replaced the seal or could it be something simple like my TB tensioned too tight??? Maybe making the camshafts rotation wobble a little? I cant see the wobble, but something is making the seal not do its job... Oil leaks make my skin crawl :(
Thanks for any input.
Joseph
1979 Diesel Rabbit L - 60k :)
1982 Diesel Caddy (RIP) now 1.8L Gasser
1998 Passat Wagon
Reply #1May 22, 2009, 07:54:40 pm
katakura silk
  • 92
Re: Camshaft seal is leaking???
« Reply #1 on: May 22, 2009, 07:54:40 pm »
A good hr of city driving will take the oil down to the bottom of the engine.
I know its not the Valve cover gasket. Its seeping directly behind the camshaft pulley. Also I can see the oil seeping around the seal.
What kind of sealer do I need for the cap? Do you mean to put it fully around the seal and put into place. Then place the cap back over the camshaft?(along with all the other caps in Bentley sequence...:))
Do you think this step was skipped?
I got the head from Jack @ VWdieselparts in Ohio. I called and he said belt tension could be a possibility. Then he went off and said something about the bearing in the injection pump (if bad) could cause everything to wobble making the seal not tight...But the pump is rebuilt. So thats not the issue.
Could this have been a bad seal?
1998 Passat Wagon
Reply #2May 23, 2009, 12:29:59 am
  • 3468
    • McScrubbins Body Wash
« Reply #2 on: May 23, 2009, 12:29:59 am »
Changing the seal is actually as easy as changing the tension of the belt IMO. take the cam cover off, turn the engine over to TDC and just take the cam completely off... No harm can come of all the valves closing, just be dang sure you put it back on the right way and not upsidedown.
Easy seal swap. I think a new seal is like 15$ cad. and preesssss it on there with some RTV or what ever as suggested.
Reply #3May 24, 2009, 07:27:54 pm
katakura silk
  • 92
« Reply #3 on: May 24, 2009, 07:27:54 pm »
Thanks for clearing that up for me!!! I will post results soon.
The lady has got me painting almost every room in our house this weekend. :(
1998 Passat Wagon
Reply #4June 07, 2009, 08:55:19 am
katakura silk
  • 92
« Reply #4 on: June 07, 2009, 08:55:19 am »
:UPDATE:
Pulled the cam.
Had to make a home made seal press.
Used aviation sealer on Cap #1
No more oil leaks as of yet.
Went ahead and made the jump to Synthetic...
I wanted to ask another question. I have read that synthetic oil has detergents that break up soot. Since I just made the change from 15w-40(from the ground ;)) to 5w-40 synthetic, should I change this oil a little sooner than normal.(for the first change)  Maybe around 3,000.  I dont know if the car burned any oil before because of the oil leak @ the cam seal. I only had to add 1/2 QT in 3,000 miles...
1998 Passat Wagon
Reply #5June 07, 2009, 12:21:52 pm
« Reply #5 on: June 07, 2009, 12:21:52 pm »
I'm not talking about the perimeter of the seal itself, I am talking about the mating surface of the 1st cam bearing cap to the head.  Without sealant, oil will weep there between the head and cap.
Andrew
You Andrew, are a genius :D, I've never thought of it leaking there, and there's a good chance that's the cause of one of my leaks ::).
