Author Topic: Feeler: 1.6 N/A Diesel longblock 139k in pieces  (Read 3609 times)
May 04, 2009, 11:13:04 pm
lzmdzsem
  • 5
« on: May 04, 2009, 11:13:04 pm »
ran it out of oil then put oil back in and drove it a few more hundred miles. long story short the crank is scored under the thrust bearing and one of the main bearings, i rescued what i think to be a running longblock from a junkyard and want to see what i can get for the remains of the other. the head is a 1.5 N/A head with unknown miles on it but was working fine when i pulled it off. the crank is out as well as the oil pan ect. i can reassemble it for you if you'd like but the crank needs to be turned so that seems pointless...let me know what you think it's worth and if you have any other questions.
pics to be posted ASAP.
(the engine is located at 84601)
Thanks! Luke Z
'82 VW Jetta N/A diesel ~140,000 miles
