Author Topic: Where to put a pyrometer probe in 1.6td  (Read 15416 times)
May 03, 2009, 09:41:27 pm
Familydiesel
  • 154
« on: May 03, 2009, 09:41:27 pm »
Where and how do you place a pyrometer probe in the 1.6 td exhaust?  I am thinking of placing it before the turbo, but where does it go, or where is the best pace, and how do you do it?
Thanks,
Greg
1980 Diesel td pickup, Love that Diesel!
Reply #1May 03, 2009, 10:25:35 pm
cyrus #1
  • 360
« Reply #1 on: May 03, 2009, 10:25:35 pm »
You're going to want to put it into the exhaust manifold pre turbo.  It's probably best to pull the manifold to drill and tap.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #2May 03, 2009, 10:49:51 pm
Familydiesel
  • 154
« Reply #2 on: May 03, 2009, 10:49:51 pm »
Where exacly is the best place to drill and tap the manifold?  Any place to avoid which is susceptible to cracking?
Thanks
Greg
Reply #3May 04, 2009, 06:35:16 am
saurkraut
  • 904
« Reply #3 on: May 04, 2009, 06:35:16 am »
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #4May 04, 2009, 10:59:24 am
Familydiesel
  • 154
« Reply #4 on: May 04, 2009, 10:59:24 am »
Wow, thanks for the picture and the input.  Perfect.  Thanks
Greg
Reply #5May 04, 2009, 12:17:02 pm
« Reply #5 on: May 04, 2009, 12:17:02 pm »
Added to the FAQ. :wink:
Reply #6May 04, 2009, 12:41:02 pm
  • 3468
    • McScrubbins Body Wash
« Reply #6 on: May 04, 2009, 12:41:02 pm »
Damn, too slow on the draw! Oh well... :P
Reply #7May 04, 2009, 01:00:29 pm
« Reply #7 on: May 04, 2009, 01:00:29 pm »
Good stuff y'all.
Reply #8May 04, 2009, 07:07:31 pm
Rabbit TD
  • 840
« Reply #8 on: May 04, 2009, 07:07:31 pm »
Just don't even attempt it without taking the manifold off but that's where everybody puts them and it works great there.
Reply #9May 04, 2009, 08:31:28 pm
« Reply #9 on: May 04, 2009, 08:31:28 pm »
wheres a good spot to put the probe on a VNT 17? i thought about putting it in my egr cover, but im not quite sure it will stick far enough into the manifold to get an accurate reading..
Reply #10May 05, 2009, 08:44:57 pm
« Reply #10 on: May 05, 2009, 08:44:57 pm »
Quote from: "libbybapa"
Quote from: "fatmobile"
I got a VDO, EGT setup and am putting it in one of the bracket mount bolt holes:
 I saw this done over on the old board, can't remember who posted it and the picture isn't there anymore.
...and 1 more:
Does it look like it sticks far enough into the exhaust stream?
 I could probably grind off some of the extra threads and get it to go in farther.
Wait wait wait... So with this configuration you don't have to drill in to your exhaust manifold at all?  What motor was this on??
Reply #11July 20, 2009, 07:52:44 am
derekp
  • 94
Re: Where to put a pyrometer probe in 1.6td
« Reply #11 on: July 20, 2009, 07:52:44 am »
I would like to know about this as well.
Does one simply have to run a drill bit appropriate for 1/8 inch pipe thread tap thru the bracket bolt hole and tap it?
What year is that manifold off of?
thanks!
The fleet
92 eco diesel (my driver turned project)
94 suburban (mine)
69 Chevelle 327 w/hillborn - resting nicely
89 Jetta coupe (sons 16v ABA head swap w/turbo and megasquirt - not run yet)
2000 jetta (other sons)
98 jetta (daughters)
2001 jetta tdi (girlfriends)
03 subaru outback (girlfrie
Reply #12July 20, 2009, 08:40:17 am
arb
« Reply #12 on: July 20, 2009, 08:40:17 am »
I would use a drill press. I tried to hand drill mine at first and when the bit dug-in at the end of making the hole, it cracked the manifold and I had to weld it...
Reply #13July 20, 2009, 10:29:18 am
airhead
« Reply #13 on: July 20, 2009, 10:29:18 am »
Well if you used progressively larger drill bits it might reduce the risk of this. That's what I'd do anyway.
Reply #14March 31, 2010, 05:02:51 pm
  • 3468
« Reply #14 on: March 31, 2010, 05:02:51 pm »
I used a number of bits to drill mine. I REALLY didn't want to crack the manifold.
LOTS of oil too while drilling.
