Author Topic: Permenant fusible link repair  (Read 3813 times)
September 03, 2005, 08:29:07 pm
Patrick
  • 1034
« on: September 03, 2005, 08:29:07 pm »
Walked into the local truck parts place on friday and purchased a 50 amp circuit breaker, cole-hershee, although others are available. Two screws to hold it down, two posts with nuts for the wires.
7.99.
Should be a permenant fix, working good so far!
Probably find them cheaper, maybe for nothing at a truck wrecker. I'll post a part number if anyone's interested.
Reply #1October 02, 2005, 10:31:11 am
Hammy
  • 169
« Reply #1 on: October 02, 2005, 10:31:11 am »
Thats an awsome idea, Patrick. Is it somewhat, weatherproof, or did you mount it inside the car?
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
'98 GMC 1500 4x4, 5.7L (doing my best to save the oil companies, 85 liters takes me 600 km)
'78 Ford 3000 3cyl, 201 diesel, with loader
Reply #2October 03, 2005, 04:55:58 pm
Patrick
  • 1034
« Reply #2 on: October 03, 2005, 04:55:58 pm »
Just unhooked the two existing wires and hooked them on the breaker, wire ends fit. Took a screw out of the holdown for the fusible link and used it to mount the breaker. Probably should add a second screw (the spacing is different. I'd bet on longer life under the dash instead of under the hood, but I bet gooping it up with silicone would do wonders too.
Fixmyvw.com
