Author Topic: Parts help for 1.6/1.9 frankenstein  (Read 2883 times)
May 02, 2009, 06:26:02 pm
barrygti
« on: May 02, 2009, 06:26:02 pm »
Right I am tryin to order parts for my engine build.
I have a 1.6 Hydro engine and going to put my 1.9 head on it.
I am going to order all parts from AutohausAZ as I have had parts from them in the past to New Zealand and was great service.
I need to order a timing belt and tensioning roller from a 1.6, but what engine code do I use? I can't find a code on the 1.6D Hydro engine?
I also need an MLS gasket and I suspect head bolts, so what age of VW and engine code do I use to order?
Thanks guys,
Barry
Reply #1May 02, 2009, 07:38:34 pm
barrygti
« Reply #1 on: May 02, 2009, 07:38:34 pm »
Ok If I have worked it out right I need:
Gasket from AAZ engine, but a 1 notch as the 1.9 head lowers compression anyway?
Timing belt and roller from ME engine code?
What head bolts though? And what gasket set, do I get all the 1.6D exhaust and intake gaskets, do they fit on 1.9 head ok?(I will know this when I take it apart but need to order parts first obviously.
Reply #2May 02, 2009, 08:25:06 pm
Turbinepowered
  • 1206
« Reply #2 on: May 02, 2009, 08:25:06 pm »
Size your gasket based properly on your piston protrusion. It's a tight tolerance already, and going tighter might cause damaging contacts.
Intake valve port shape is different on the 1.6 and 1.9 heads.
Reply #3May 02, 2009, 09:24:43 pm
barrygti
« Reply #3 on: May 02, 2009, 09:24:43 pm »
So does that mean the 1.6 intake won't fit on a 1.9 head?
Reply #4May 03, 2009, 08:20:07 am
« Reply #4 on: May 03, 2009, 08:20:07 am »
Quote from: "barrygti"
port the head to the intake gasket, and then port the intake.  there should be enough meat to do it.  you really can't beat prothe's TDI intake for this situation...
Reply #5May 03, 2009, 08:29:43 am
subsonic
  • 1836
« Reply #5 on: May 03, 2009, 08:29:43 am »
Where are you located Barry?
Reply #6May 03, 2009, 12:11:38 pm
barrygti
« Reply #6 on: May 03, 2009, 12:11:38 pm »
New Zealand mate.
I can't use a TDi intake as it will sit too high and hit the bonnet I believe.
