TDI Engine -General Info
timing belt damage TDI
Topic: timing belt damage TDI (Read 3224 times)
May 02, 2009, 05:05:20 pm
dieselherb1
May 02, 2009, 05:05:20 pm »
I have a 2000 TDI engine TB broke. Main damage cam,lifters, valve stems. Is there a easy method to removing mashed lifters and bent stems? Pistons look fine, head has a few marks only.
Thanks Herb
May 03, 2009, 06:20:27 am
jasonsansfleece
May 03, 2009, 06:20:27 am »
Had the same problem with a 1.6IDI head, valve stems driven into the lifters, could not pull the lifters out. Had a friend weld a bolt to the top of each stuck lifter, then used vise grips to pull them out.
Guy
May 03, 2009, 07:21:03 am
dieselherb1
May 03, 2009, 07:21:03 am »
Good idea Thanks! I have a MIG.
