Author Topic: Leaking IP Pump  (Read 4873 times)
Reply #15April 28, 2009, 08:18:33 pm
Leaking IP Pump
« Reply #15 on: April 28, 2009, 08:18:33 pm »
but pumps are soo easy to work on. they arent nearly as complex as i first thought. i was scared to death to work on one, but then one day i tore one open. they are pretty simple. you arent even gonna have to dig that far into yours to fix it. i tore mine down to a million pieces today to fix it. broke the shaft that goes into the actual pump.
Reply #16April 28, 2009, 08:21:02 pm
catlin_cava
  • 1954
Leaking IP Pump
« Reply #16 on: April 28, 2009, 08:21:02 pm »
i need to get the thing working and changing pumps was the easiest bet, and thats what 2 shops told me to do and play with the other pump after
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #17April 28, 2009, 08:30:02 pm
Leaking IP Pump
« Reply #17 on: April 28, 2009, 08:30:02 pm »
Been there done that :roll: . For very little money I could've had a spare working pump but no dice.
Reply #18April 30, 2009, 12:22:25 pm
Leaking IP Pump
« Reply #18 on: April 30, 2009, 12:22:25 pm »
Quote from: "catlin_cava"
the amount of work required to change the pump is probably more than to change the problem seal and even bushing.  you'll need to get the timing set to do it properly too.
go through Vince's timing guide and you'll get an idea of what you're getting into with a complete pump change.  :wink:
don't forget that a pump sitting for even just a few months can go south, although generally not the case if stored properly (full of fuel and all ports blocked off).
