Author Topic: shave or not to shave  (Read 2472 times)
April 27, 2009, 08:46:48 am
Duster 5.9
  • 96
« on: April 27, 2009, 08:46:48 am »
Ok i see alot of people asking about flat heads. some say you can shave and some say no  I want all your input on this just to clear things up. thank you.
p.s. i believe the bently say's no.
81 rabbit gas resting
81 rabbit cabby diesel n/a
85 jetta diesel n/a
85 golf diesel runs great
82 caddy diesel clean
82 caddy gas solid resting
and some parts cars
Reply #1April 27, 2009, 09:31:07 am
arb
« Reply #1 on: April 27, 2009, 09:31:07 am »
I would think you are only thinking about shaving because your head is not flat. How did it become that way ? Over heated ? You could find it has cracks after you spend the money to shave it. Then you have to deal with the cups sticking down too low. You don't want to grind them. That's probably why Bentley says no.  I would be looking for another head.
Reply #2April 27, 2009, 09:36:32 am
arb
« Reply #2 on: April 27, 2009, 09:36:32 am »
Quote from: "libbybapa"
I've had several shaved with pre-chambers in and never had an issue.
The cutting tool was sharp / strong enough to cut through both at the same time?  Cool. The time I worked as a machinist we never cut mixed metals like that, so it have tainted my views on that.
Reply #3April 27, 2009, 09:38:39 am
« Reply #3 on: April 27, 2009, 09:38:39 am »
i guess your not supposed to do it but i've seen many heads get shaved down with the pre cups in, usually just to true them up a bit.
Reply #4April 27, 2009, 09:43:14 am
arb
« Reply #4 on: April 27, 2009, 09:43:14 am »
I've never shaved them personally, but the machinist I've used has.  I don't know his process but I'm sure the pre-cups were installed at the time.
I have hand lapped a head with 120 git on a slab of granite with success.
Now this I couold see as a perfectly viable methode, if the cups didn't get too thin ;-)
Reply #5April 27, 2009, 06:38:31 pm
Duster 5.9
  • 96
« Reply #5 on: April 27, 2009, 06:38:31 pm »
i'm currently not doing this i was just asking a question  because i see so many yeh and neh's. how thick is a precup? i've never looked at one and have no idea how there put in. could they be pulled? then the opening machined , then reinstalled? i personnally have no clue, but just wondering. thanks.
85 jetta diesel n/a
and some parts cars
Reply #6April 27, 2009, 07:40:15 pm
« Reply #6 on: April 27, 2009, 07:40:15 pm »
I had new precups installed in my head when it was shaved and had the machine shop recess them down about .010 is all.
Took it to the Auto machine shop and they shaved it flush. They also had the machine that grinds VS shaving but as i had them recessed the .010 it was fine on the reg machine.
If your head isn't out much go ahead and have it shaved.
Also on the Precup thickness. The part you see if pretty thick, if your head was only say .010 out that's not enough to hurt them. they are approx .125 thick.
Reply #7April 27, 2009, 09:14:51 pm
Duster 5.9
  • 96
« Reply #7 on: April 27, 2009, 09:14:51 pm »
Quote from: "zukgod1"
Hey zukgod1 where have you been? Yes this was the exact answer I was looking for. thank you.
also it is true that you can get new precups?
85 jetta diesel n/a
and some parts cars
