Author Topic: Glow plug light not going on.  (Read 4576 times)
April 26, 2009, 09:00:41 pm
Nessy
  • 2
« on: April 26, 2009, 09:00:41 pm »
My car hasn't been starting well for about 1 month than about 1 week a go the glow plug light doesn't turn on anymore when i go to turn on my car it just chugs. I thought this was because my glow plugs arnt working so i changed my glow plugs but the light doesnt go on. what could this be im new to diesels
Reply #1April 26, 2009, 09:11:59 pm
« Reply #1 on: April 26, 2009, 09:11:59 pm »
Unfortunately the light on the dash is not actually connected to the glow plugs... it's connected to the glow plug relay (big tall sucker on the fuse panel).
If the light was working but stopped *and* the car is hard to start it's a reasonable guess that the glow plug relay has gone south... swapping in a new one is probably the easiest test.
If you have a multimeter or test light you can confirm power at the glow plug buss and work your way back.
Reply #2April 26, 2009, 09:20:00 pm
Re: Glow plug light not going on.
« Reply #2 on: April 26, 2009, 09:20:00 pm »
Quote from: "Nessy"
im new to diesels
BTW... welcome to the forum Nessy!!
You're gonna have fun... I'd highly recommend you give the FAQ a once-over to get you started, and we also recommend you put your location in your profile in the event you have a question or comment that has a geography component to it.
Reply #3April 26, 2009, 09:41:49 pm
Nessy
  • 2
« Reply #3 on: April 26, 2009, 09:41:49 pm »
Okay thank you so much :) i put my location to :P lol
Reply #4April 26, 2009, 09:50:05 pm
« Reply #4 on: April 26, 2009, 09:50:05 pm »
Quote from: "Nessy"
Merci!!
Reply #5May 03, 2009, 02:30:49 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
« Reply #5 on: May 03, 2009, 02:30:49 pm »
It could also be the glow plug fuse by the firewall no? I'm having a similar issue except the light is staying on longer than it should. I would check the fuse first.
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #6May 03, 2009, 04:00:32 pm
« Reply #6 on: May 03, 2009, 04:00:32 pm »
Nah, sadly the light has a mind of its own... not related to the fuse.  The fuse is downstream of the glowplug relay and protects the heavy-duty wiring that provides 60 amps to the glow plug buss.
In your case, if the light is staying on too long the glowplug relay thinks it's cold out.  This can be caused by a defective temp sensor, broken/damaged wiring to the sensor, or a defective glow plug relay.
I usually start by checking the wiring at the sensor itself... it can break and/or disconnect itself, particularly given the vibrations of the average diesel.  After that, the sensor is only a few bucks...  :wink:
Reply #7May 04, 2009, 11:44:35 am
jettabrendan
  • 198
« Reply #7 on: May 04, 2009, 11:44:35 am »
Well if you need a gp relay I have one with your name on it. Oh and which sensor is it that is related to the gp. I replaced both on the collar on the front of the head. Still stays on.
