Author Topic: fan problems  (Read 3578 times)
April 24, 2009, 12:15:02 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
fan problems
« on: April 24, 2009, 12:15:02 pm »
My fan only turns on when I have the AC on. I don't like to turn on my AC because it starts squealing and is annoying. It also turns on when I turn on the heat, but so does the AC compressor. I don't know the first thing about this kind of problem but I'm thinking its the thermo sensor. The after run also does not work. Thanks
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #1April 25, 2009, 04:38:56 am
Re: fan problems
« Reply #1 on: April 25, 2009, 04:38:56 am »
Quote from: "jettabrendan"
check the temp of the rad.  i usually use my fingers touching it briefly (it can get quite hot). its probably the thermo sensor if the rad is getting hot enough.  you can pull off the harness from the thermoswitch and jump the terminals with a paperclip or other metallic piece.
