Author Topic: Unusual Smell  (Read 3723 times)
April 08, 2009, 01:37:31 pm
catlin_cava
  • 1954
Unusual Smell
« on: April 08, 2009, 01:37:31 pm »
I went out with the car today and when the heat is on it smells strong like prestone, yet the level never moves. Maybe i should of stayed home like i was supose too
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1April 08, 2009, 02:30:23 pm
hamradio
  • 282
Unusual Smell
« Reply #1 on: April 08, 2009, 02:30:23 pm »
Heater core?
My car's heater core leaks enough to put a heavy antifreeze smell in the cabin, but not really effect level heavily.
Reply #2April 08, 2009, 03:20:33 pm
catlin_cava
  • 1954
Unusual Smell
« Reply #2 on: April 08, 2009, 03:20:33 pm »
hmmm, i'll have to look at it once i can crawl around...i drove today and can't walk tonight...
Catlin
Reply #3April 08, 2009, 04:23:43 pm
Unusual Smell
« Reply #3 on: April 08, 2009, 04:23:43 pm »
Quote from: "catlin_cava"
you can't walk tonight because of the fumes?  :shock: do NOT inhale those fumes!!! you can go blind or die!!!
i'm in the process of rebuilding my heater box with new foam and new heater core.  i think i found the secret to doing the heater core without removing the a/c box as well though... there is two little clips in behind and one on top (that i broke anyways)  personally i'd rather just use those tie straps for easy removal, but its all back in anyways.  man what a job!!! the foam crumbles into dust!  i do not envy anyone who has to do this job...
Reply #4April 09, 2009, 05:44:25 am
arb
Unusual Smell
« Reply #4 on: April 09, 2009, 05:44:25 am »
I see a new heater core in your near future, if you don't drive the car until then... the stuff is toxic to dogs and humans ;-D
Reply #5April 09, 2009, 06:41:10 am
catlin_cava
  • 1954
Unusual Smell
« Reply #5 on: April 09, 2009, 06:41:10 am »
Knee surgery...And the smell is not there if the heat is not on...
Catlin
Reply #6April 09, 2009, 06:49:43 am
arb
Unusual Smell
« Reply #6 on: April 09, 2009, 06:49:43 am »
You likely have the older coolant shut-off valve for your heater core. The leak will be worst, so if you are keeping the car, you should plan on replacing it sooner than later.
Reply #7April 09, 2009, 06:56:07 am
catlin_cava
  • 1954
Unusual Smell
« Reply #7 on: April 09, 2009, 06:56:07 am »
I am going to replace it, I'm getting my old MK3 back and going to use it for parts, I know the heater core in there is fine. I find it funny that its leaking and its a 97
Catlin
Reply #8April 09, 2009, 07:11:40 am
arb
Unusual Smell
« Reply #8 on: April 09, 2009, 07:11:40 am »
Yeah, that is rather soon. How does the radiator look ? Maybe the coolant wasn't changed when it should have and went Acidic.
Reply #9April 09, 2009, 07:25:07 am
catlin_cava
  • 1954
Unusual Smell
« Reply #9 on: April 09, 2009, 07:25:07 am »
at 367,000km and nothing was touched in the motor... the anti freeze looks clean, and the rad is in good shape. You made me limb outside to check lol :lol:
Catlin
Reply #10April 09, 2009, 07:38:34 am
arb
Unusual Smell
« Reply #10 on: April 09, 2009, 07:38:34 am »
Glad you're getting around OK :-) Speedy recovery Man !
At 12 years, I'd flush it when you change your heater core.
Reply #11April 09, 2009, 07:46:41 am
catlin_cava
  • 1954
Unusual Smell
« Reply #11 on: April 09, 2009, 07:46:41 am »
Thanks Man, Just had the surgery monday, I;ve got 2 months off work so i'm going to use the time to get the car in shape. Starting June 1st...1000km a week for 8 weeks...yay :shock:
Catlin
Reply #12April 09, 2009, 02:27:44 pm
1slowvw
Unusual Smell
« Reply #12 on: April 09, 2009, 02:27:44 pm »
heater cores are no fun, best of luck, I would really recommend if your going through all the work to replace it that you put a new one in, just so you don't end up having to do the same tedious job in another 6 months.
just my two cents.
1SlowVW
Reply #13April 09, 2009, 02:40:49 pm
catlin_cava
  • 1954
Unusual Smell
« Reply #13 on: April 09, 2009, 02:40:49 pm »
How much are heater cores anyways?
Catlin
Reply #14April 09, 2009, 02:46:52 pm
truckinwagen
  • 1895
Unusual Smell
« Reply #14 on: April 09, 2009, 02:46:52 pm »
autohausaz.com has them for $17
this is for the 97 golf in your sig right?
83 Opel Kadett Diesel
