Author Topic: The Best twin turbo set up?  (Read 8051 times)
Reply #15December 06, 2009, 11:30:51 am
Re: The Best twin turbo set up?
« Reply #15 on: December 06, 2009, 11:30:51 am »
crap... you beat me to it, thats what i was going to say too,. but at high speeds you need a big enough wastegate that when it opens it basically cuts the high pressure turbo out of the equasion pretty much, lots less restriction from it.
Reply #16December 06, 2009, 11:40:04 am
Dirtrag2
  • 298
« Reply #16 on: December 06, 2009, 11:40:04 am »
ok so the first turbo gets an external wastegate but the big one is ok as a stock t3 ( internal wg ) right?
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #17December 06, 2009, 11:41:34 am
« Reply #17 on: December 06, 2009, 11:41:34 am »
yea, it would be fine as long as the drive pressure never gets too high.
Reply #18December 07, 2009, 09:11:02 am
smokin_fun
  • 65
« Reply #18 on: December 07, 2009, 09:11:02 am »
try and find a copy of "Turbochargers" by HPBOOKS , this book is awesome! it has a section on how to calculate flows for compound setups, all the way to 200 psi manifold pressure!
I picked up a copy for 7 bucks at a used book store in langford..... best 7 dollars i ever spent!
The author of this book really stresses proper matching of turbos to motors, especially in compound setups.
Definitely a good read.
Reply #19December 07, 2009, 07:17:16 pm
Dirtrag2
  • 298
« Reply #19 on: December 07, 2009, 07:17:16 pm »
cool  8)  could you do me a favor and post the ISBN # for that book so i can order one? you will find it above the bar code usually
thanks
...Darcy
Reply #20December 08, 2009, 01:03:52 am
smokin_fun
  • 65
« Reply #20 on: December 08, 2009, 01:03:52 am »
the isbn is 0-89586-135-6. author is hugh macinnes.
this website talks about this very book (its the one pictured on the left) plus has tons of great info and turbo maps:
http://www.rbracing-rsr.com/turbotech.html
The chapter in "Turbochargers" on tractor pulling has some crazy stuff about three stage turbo chargers with water/meth injection. Each stages pressure ratio is 2.7, so 2.7x2.7x2.7x14.7=289.34 psia or 274psig!!!  Boost increases exponentially!
2 stages , having a pressure ratio of 2.36 each, would result in a manifold pressure of 67 psig,[(14.7x2.36x2.36)-14.7)] and an astronomical egt without proper inter/after cooling. (these are rough calculations, not accounting for various innefficencys, mechanical or otherwise.)
I'd love to see a three stage turbo setup on a Vw diesel.... I wonder how long one would last at 275 psi boost.. maybe if it redlined at 10,000
Reply #21December 08, 2009, 05:08:42 pm
Dirtrag2
  • 298
« Reply #21 on: December 08, 2009, 05:08:42 pm »
...Darcy
Reply #22December 08, 2009, 06:43:58 pm
expanty09
  • 8
    • ukrain bride
« Reply #22 on: December 08, 2009, 06:43:58 pm »
Anything is possible with money, of course. Me personally, if I were to do a twin turbo setup, I would use two small T25 or smaller same turbos on a 4 cylinder Accord.
Now, that would be unique.
Reply #23December 10, 2009, 08:53:06 am
« Reply #23 on: December 10, 2009, 08:53:06 am »
but, were on a VW forum here, not some retarded honda forum. saying Accord or Civic, is just about the same as saying F*** on here...
Reply #24December 10, 2009, 11:42:21 am
smokin_fun
  • 65
« Reply #24 on: December 10, 2009, 11:42:21 am »
besides the only japanese car worth working on is a Previa!
Reply #25December 10, 2009, 02:50:17 pm
« Reply #25 on: December 10, 2009, 02:50:17 pm »
BAM!!!!!!
Rabbit, I completely forgot to buzz ya on my trip up there. Crap!!  Next time..
