Author Topic: The Best twin turbo set up?  (Read 8052 times)
April 04, 2009, 02:03:17 pm
catlin_cava
  • 1954
« on: April 04, 2009, 02:03:17 pm »
What is the best twin turbo set up? One turbo boosting the other turbo...or 1 turbo for 2 cylinders?  :twisted:  we get some bad ideas when beer is involved
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #1April 04, 2009, 02:52:59 pm
catlin_cava
  • 1954
« Reply #1 on: April 04, 2009, 02:52:59 pm »
for the set up of it?
Catlin
Reply #2April 05, 2009, 10:21:00 am
« Reply #2 on: April 05, 2009, 10:21:00 am »
im gonna take and add a 300TD turbo behind my vnt. andy 2 said it should work alright. i just gotta get a motor to hold up to that much boost. and some way to get enough fuel into the engine. and some way to keep the head from shooting off and going through my hood. :lol:
Reply #3April 06, 2009, 02:04:15 pm
monomer
  • 414
« Reply #3 on: April 06, 2009, 02:04:15 pm »
Quote from: "Rabbit on Roids"
300D.
-both 3K and Garrett/Air research made turbos for them. The 3K (KKK) is more desirable. Not very big turbo's at all. If your using a vnt to spool on the low-end, why not go a little bigger? 60-1 anyone?
("T" does not refer to turbo in Mercedes speak - "T" indicates "touring" - a wagon body)
-Both turbos are internally gated, 8psi If I remember correctly. More CFM, but not more boost. Wastegate actuators are normally VAC CONTROLLED in Mercedes, a pressure activated unit will have to be installed also.
www.michiganvw.org
Reply #4April 07, 2009, 06:47:33 am
foxracer1
  • 991
Re: The Best twin turbo set up?
« Reply #4 on: April 07, 2009, 06:47:33 am »
Quote from: "libbybapa"
Quote from: "catlin_cava"
Two turbos each serving two cylinders has no advantage over one turbo serving all four cylinders unless it simplifies plumbing, e.g. H-4 motor where bringing all the pipes to one turbo would be cumbersome.
It is look at a subaru pipe everywhere.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #5April 07, 2009, 09:40:37 am
« Reply #5 on: April 07, 2009, 09:40:37 am »
Quote from: "monomer"
300D.
only reason im not going with a bigger VNT, is because im VERY limited on funds. i still have less than 500 dollars into my car. the turbo was free. i just want to make due with what i have. ans when i said 300td, i just meant a 300 series merc with a turbo motor. i wasnt going into sub models, like TD or SD or anything like that. and now that i have an intercooler installed, i should be good to go for more boost. now i just have to fix the oil pan.. and the head gasket..
Reply #6April 07, 2009, 08:24:56 pm
« Reply #6 on: April 07, 2009, 08:24:56 pm »
isn't there an advantage with pulsing if done properly?   i thought thats why twin turbos was popular on v6's for a while like the 300zx and 3000gt
Reply #7April 08, 2009, 11:10:23 am
« Reply #7 on: April 08, 2009, 11:10:23 am »
Quote from: "Trev0rbr"
but dont you have to have a single turbo with a split exhaust housing to pulse your turbo? and have it so that it alternates the pulses evenly between the 2 sides? thats how i always understood a pulse setup..
Reply #8December 03, 2009, 06:35:41 pm
Dirtrag2
  • 298
« Reply #8 on: December 03, 2009, 06:35:41 pm »
thought i'd bring this back up...
I'm considering running a compound set up on my aaz, my T3 on starts to spool at about 2800 RPM and i just thought that by using a smaller turbo, either a K03 or a K14 I can take advantage of early spool-up as well as higher psi from the T3.  what are the disadvantages to this type of set-up vs the gains?
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #9December 03, 2009, 06:50:05 pm
« Reply #9 on: December 03, 2009, 06:50:05 pm »
With an MBC set at the same boost level, Your T3 will be fully spooled by 2800, possibly even sooner.
Reply #10December 03, 2009, 08:35:40 pm
foxracer1
  • 991
« Reply #10 on: December 03, 2009, 08:35:40 pm »
I was gonna say i'm making 18-19 psi by 2800
91 S10 305 TPI T56
Reply #11December 04, 2009, 02:35:59 pm
Dirtrag2
  • 298
« Reply #11 on: December 04, 2009, 02:35:59 pm »
yeah but i'd like to hit 15-18 psi by1800 and 30psi by 2800  ;D
ok, maybe a bit optimistic but 10-12 psi by 1800 & 25 psi by 2800
« Last Edit: December 04, 2009, 07:58:13 pm by Dirtrag2 »
...Darcy
Reply #12December 05, 2009, 09:16:55 pm
foxracer1
  • 991
« Reply #12 on: December 05, 2009, 09:16:55 pm »
Yeah i'd loikre more boost earlier and even more up top. My concern is the small turbo isn't going to flow enough up top haven't figured it out yet just got trial and error i guess. watch drive pressure vs boost pressures
91 S10 305 TPI T56
Reply #13December 06, 2009, 10:19:32 am
Dirtrag2
  • 298
« Reply #13 on: December 06, 2009, 10:19:32 am »
from the research i've done and from what i understand  ::) the setup would be as such... oh and I don't have to worry too much about space 'cus this will be mounted in my Projekt Fox http://www.vwdiesel.net/forum/index.php?topic=16098.0
hot side:custom exhaust mani to small turbo to custom pipe to big turbo to exhaust
buisness side: air filter to small turbo ( wastegete set to 15 psi ) to big turbo ( set to 28 psi ) to intake manifold.
does this sound right??
are there any other considerations i haven't thought of??
...Darcy
Reply #14December 06, 2009, 11:09:57 am
rallydiesel
  • 1880
« Reply #14 on: December 06, 2009, 11:09:57 am »
You can forget about running an internal wastegate on the small turbo. You'll have way too much restriction leading to high emp's and egt's. It'll blow the headgasket for sure. You'll need need an external wastegate to bypass the small turbine at high flow.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
