Author Topic: Pre cup cracks....  (Read 4479 times)
April 01, 2009, 04:15:26 pm
Kantdrivefast
  • 196
Pre cup cracks....
« on: April 01, 2009, 04:15:26 pm »
Well I got around to taking the head off and found these.
How bad are these. Worth rebuilding?
Reply #1April 01, 2009, 04:25:43 pm
Pre cup cracks....
« Reply #1 on: April 01, 2009, 04:25:43 pm »
daily or race car?
Reply #2April 01, 2009, 04:30:14 pm
Kantdrivefast
  • 196
Pre cup cracks....
« Reply #2 on: April 01, 2009, 04:30:14 pm »
Daily with a little more fuel and boost.
Nothing too fancy.
Whats the verdict..... find a new one? Or put this one together?
Reply #3April 01, 2009, 04:47:48 pm
Pre cup cracks....
« Reply #3 on: April 01, 2009, 04:47:48 pm »
can you get just new pre cups?
Reply #4April 01, 2009, 04:52:39 pm
Kantdrivefast
  • 196
Pre cup cracks....
« Reply #4 on: April 01, 2009, 04:52:39 pm »
Where from. I searched the thread and all I could come up with was that new ones are pretty much pure unobtainium.
I was also referring to the cracks inbetween the valves. Are they too large?
Reply #5April 01, 2009, 05:03:50 pm
Pre cup cracks....
« Reply #5 on: April 01, 2009, 05:03:50 pm »
new swirl chambers are available.  i recall viewing a post linking to a vendor that listed a plethora of different chambers of all types for all makes.  don't know where it is now, and a search might take a while to sift through.
Reply #6April 01, 2009, 05:30:01 pm
bigblockchev
  • 271
Pre cup cracks....
« Reply #6 on: April 01, 2009, 05:30:01 pm »
I wouldn't worry too much about the cracks between the valves they are pretty normal. Bentleys even gives a spec for the max size and those don't look even close. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
Reply #7April 01, 2009, 08:45:05 pm
diesel smoke
  • 209
Pre cup cracks....
« Reply #7 on: April 01, 2009, 08:45:05 pm »
You got to get ahold of this guy: http://forums.tdiclub.com/member.php?u=31923
He does IDI heads too. I'm going to send him the one from my '89 for a complete refurbishing. It needs it.  8)
'99.5 Bora TDI
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
Reply #8April 02, 2009, 01:44:24 pm
Pre cup cracks....
« Reply #8 on: April 02, 2009, 01:44:24 pm »
will a 1.9 precup fit in a 1.6 head?
Reply #9April 02, 2009, 09:03:49 pm
Pre cup cracks....
« Reply #9 on: April 02, 2009, 09:03:49 pm »
Quote from: "Trev0rbr"
i'm pretty sure they're a bit bigger.  which is why using the 1.9 head on the 1.6 makes it a little harder to start.
frank06 on TDIclub only does TDI heads though right??? maybe he can get the swirl chambers though?
Reply #10April 02, 2009, 09:16:27 pm
diesel smoke
  • 209
Pre cup cracks....
« Reply #10 on: April 02, 2009, 09:16:27 pm »
Quote from: "jtanguay"
Nope, he can do both IDI and TDI. You would have to ask him about the swirl chambers though. 8)
'99.5 Bora TDI
'88 Fox Coupe
'85 Mercedes 300SD
Reply #11April 02, 2009, 09:26:46 pm
Pre cup cracks....
« Reply #11 on: April 02, 2009, 09:26:46 pm »
Quote from: "diesel smoke"
ah pretty cool!  hopefully he doesn't charge too much.  those new chinese heads are very cost effective  :lol:
Reply #12April 02, 2009, 09:39:56 pm
diesel smoke
  • 209
Pre cup cracks....
« Reply #12 on: April 02, 2009, 09:39:56 pm »
I don't even know where one could get a genuine German head... :x
'99.5 Bora TDI
'88 Fox Coupe
'85 Mercedes 300SD
Reply #13April 02, 2009, 09:40:56 pm
Pre cup cracks....
« Reply #13 on: April 02, 2009, 09:40:56 pm »
My vote... for a daily driver the head appears fine... cracks between the valves are smaller than many I've seen (in general a dime is the thickness limit), and the pre-chambers are beginning to show some stress fractures but given how thick they are they probably have many many miles left.
I'd have it surfaced, rebuilt as required (guides, seals, etc) and carry on.
Reply #14April 03, 2009, 03:26:32 am
  • 3468
    • McScrubbins Body Wash
Pre cup cracks....
« Reply #14 on: April 03, 2009, 03:26:32 am »
As another reply to the valve cracks coming from a guy who had to get a new head because of them....
my cracks in my 1.6head were enormous in comparison. An actual gap. Just visible cracks are nothing man. I wasn't so forum savy back then and i didn't think to take pictures of how big they were to show how big mine were to screw over my cooling system.
I later threw it into the local "transfer station" pit with much rejoicing following.
