Author Topic: brake light 1981 caddy  (Read 3883 times)
April 01, 2009, 01:33:58 pm
Duster 5.9
  • 96
« on: April 01, 2009, 01:33:58 pm »
the brake light stay's on in my caddy. why? I did do a search but the search engine was of nooo help.
81 rabbit gas resting
81 rabbit cabby diesel n/a
85 jetta diesel n/a
85 golf diesel runs great
82 caddy diesel clean
82 caddy gas solid resting
and some parts cars
Reply #1April 01, 2009, 05:06:13 pm
Re: brake light 1981 caddy
« Reply #1 on: April 01, 2009, 05:06:13 pm »
Quote from: "Duster 5.9"
for the e-brake?
Reply #2April 02, 2009, 01:30:32 pm
Duster 5.9
  • 96
« Reply #2 on: April 02, 2009, 01:30:32 pm »
the big read light next to the seat belt light that says brake.
85 jetta diesel n/a
and some parts cars
Reply #3April 02, 2009, 11:17:11 pm
CODE4LS1
  • 73
« Reply #3 on: April 02, 2009, 11:17:11 pm »
Sometimes a worn e-brake will not sit full on the switch that turns off the light when let down.  Had this problem with a few vw's
Reply #4April 09, 2009, 04:48:56 am
somolovitch3
  • 290
« Reply #4 on: April 09, 2009, 04:48:56 am »
That switch is located just in front of the e-brake bracket, if the light goes out when you push the switch down, the problem is in the position of switch, the e-brake position, .....  Or you can unplug the switch and see if it goes out.
If it is still on, you have uneven brake pressure, and its back to the Bentley. :twisted:
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #5April 11, 2009, 02:50:13 pm
Duster 5.9
  • 96
« Reply #5 on: April 11, 2009, 02:50:13 pm »
Man i feel like a (BLANK)! ya it was the switch was poped off to the side. thanks to all you GREAT! people!
85 jetta diesel n/a
and some parts cars
