Author Topic: Pulsation?  (Read 1992 times)
March 31, 2009, 05:06:46 am
Jettage1
  • 202
    Past VWs: 80 Scirocco S, 90 GTI, 00 Passat GLX
Pulsation?
« on: March 31, 2009, 05:06:46 am »
So what would cause a pulsation felt in your forward motion under light/moderate acceleration?  It is not violent bucking at all, just a sort of forward / rearward motion, or I guess you'd say a rhythmic lack of consistency or smoothness in power delivery.  The car didn't always do this, so I know it's not normal.
The IP is bolted down tight, and I believe the clutch is fine.  Timing is around 1.00 and IP & injectors are new.  Is there some IP adjustment that would create or eliminate this sort of condition?  Maybe some sort of a fuel delivery issue?
Thanks guys.
Steve
92 Jetta EcoDiesel
     pumped by Giles...powered by Frybrid...functional by dumb luck
Reply #1April 01, 2009, 01:27:06 pm
Duster 5.9
  • 96
Pulsation?
« Reply #1 on: April 01, 2009, 01:27:06 pm »
have you changed the filter lately? do you see any bubbles inline? anything leaking?
81 rabbit gas resting
81 rabbit cabby diesel n/a
85 jetta diesel n/a
85 golf diesel runs great
82 caddy diesel clean
82 caddy gas solid resting
and some parts cars
Reply #2April 01, 2009, 02:15:34 pm
Jettage1
  • 202
Pulsation?
« Reply #2 on: April 01, 2009, 02:15:34 pm »
Nothing's leaking, haven't seen bubbles, pump bolts are tight.  Will inspect motor mounts.
Haven't changed filter in awhile...  maybe that's a candidate.
Someone also suggested that excessive crankcase oil being burned (either from blowby or from the turbo) could lead to inconsistent behavior since the engine wouldn't be entirely controlled by the IP...
I disconnected the crankcase-to-intake return but no difference.  Since I do have some gray smoke under load I'm considering a turbo rebuild...
Steve
92 Jetta EcoDiesel
