Author Topic: AAZ blue smoke  (Read 3312 times)
March 30, 2009, 03:27:17 pm
veersixoh
  • 16
AAZ blue smoke
« on: March 30, 2009, 03:27:17 pm »
I had the car looked at by my local vw dealer... there's a diesel guy there.  The car was blowing soot and blue smoke out the pipe.  The diagnosis was messed up timing and blamed on the guys that did the timing belt.
The car only smoked when the choke was off.. when it was on, it was fine. They adjusted it and it went away for a few days, but now I had the car running with the choke off and it started to sputter again and smoked blue.
When I rev the car there is no smoke until the revs go back down to idle... that's when a blue puff of smoke comes out.
Is this just a matter of getting the timing right or is there something else like a headgasket or piston rings?  Car has 315k km.
Thanks
Reply #1March 30, 2009, 10:19:23 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
AAZ blue smoke
« Reply #1 on: March 30, 2009, 10:19:23 pm »
the turbo could be leaking oil
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #2March 31, 2009, 02:38:58 am
Golf/Jetta
  • 102
AAZ blue smoke
« Reply #2 on: March 31, 2009, 02:38:58 am »
does it still smoke when you pull the choke?
could also be, valve stem seals.
cracked block
bad fuel
http://vwdiesel.net/phpBB/viewtopic.php?t=19118
not enought oil to cause it to runaway
whats the history on the engine?
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
Reply #3March 31, 2009, 03:53:07 am
veersixoh
  • 16
AAZ blue smoke
« Reply #3 on: March 31, 2009, 03:53:07 am »
When the choke is pulled out, it stops smoking and sputtering... but the thing is that it just had the timing properly adjusted and it's still at it.
Engine has 315k, don't know the full history.  I did all belts and fluids when I got the car.
Reply #4April 01, 2009, 11:26:00 am
Golf/Jetta
  • 102
AAZ blue smoke
« Reply #4 on: April 01, 2009, 11:26:00 am »
there was a white 94 golf that went for 500 that didn't get sold for a year and sat for the year..
http://www.vwdieselparts.com/forum/viewtopic.php?t=8718&highlight=blue+smoke
they talk about air getting in the fuel line causing it to smoke blue
Reply #5April 01, 2009, 12:04:05 pm
AAZ blue smoke
« Reply #5 on: April 01, 2009, 12:04:05 pm »
Quote from: "veersixoh"
Three common areas of focus:
What timing value was used?
How are your glow plugs?
Do you have air bubbles in your lines?
Reply #6April 03, 2009, 05:28:21 pm
veersixoh
  • 16
AAZ blue smoke
« Reply #6 on: April 03, 2009, 05:28:21 pm »
As far as I know... timing values are stock as per VW dealer and service books...
Glow plugs were replaced last may...
Can't really see any air bubbles in the lines...
Reply #7April 03, 2009, 05:49:23 pm
jettabrendan
  • 198
AAZ blue smoke
« Reply #7 on: April 03, 2009, 05:49:23 pm »
my 92 has a leaky turbo, it blows out blue smoke..
Reply #8April 03, 2009, 08:33:04 pm
  • 3468
    • McScrubbins Body Wash
AAZ blue smoke
« Reply #8 on: April 03, 2009, 08:33:04 pm »
Quote from: "jettabrendan"
x2 except mines a 90 and a 1.6td
Reply #9April 04, 2009, 10:29:14 am
jettabrendan
  • 198
AAZ blue smoke
« Reply #9 on: April 04, 2009, 10:29:14 am »
I have no experience with the AAZ but usually blue smoke means burning oil. A leaky turbo wil cause runaway if its bad enough.you  don't want that to happen I'm sure. I'm sure there's other causes for blue smoke but idk. Take a few min and check out the inside of your intake tube before the air box for oil where it shouldn't be.
