Author Topic: timing  (Read 6158 times)
March 29, 2009, 12:53:55 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
timing
« on: March 29, 2009, 12:53:55 pm »
Is ther any way to time the injector pump without using a dial indicator? I do not have access to one and I can't buy one for a while.
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #1March 29, 2009, 01:43:00 pm
  • 1739
timing
« Reply #1 on: March 29, 2009, 01:43:00 pm »
If you just need to put one back on, there are marks at the top of the pump housing flange and on the bracket that will give you a good baseline. After that you could move it back and forth a bit to where it runs well without too much noise.
Reply #2March 29, 2009, 02:21:08 pm
jettabrendan
  • 198
timing
« Reply #2 on: March 29, 2009, 02:21:08 pm »
Okay that's what I thought so towards the engine is advance and retard is away? What about increments, like an eighth of an inch in whatever direction or more?
Reply #3March 29, 2009, 03:29:23 pm
timing
« Reply #3 on: March 29, 2009, 03:29:23 pm »
Quote from: "jettabrendan"
 You'd be surprised at how much an 1/8" moves the dial.. It would be good to hone in.. then use like 1/16" movements to where she runs best. as long as it sounds good, and the power is ok you should be pretty close to stock and if not, advanced a little will help with power :) and retarded will help with emissions :) Win/Win
Reply #4March 29, 2009, 05:14:53 pm
jettabrendan
  • 198
timing
« Reply #4 on: March 29, 2009, 05:14:53 pm »
well if i can get the damn thing running i can time it. it just cranks and puffs out smoke.
Reply #5March 29, 2009, 05:15:58 pm
timing
« Reply #5 on: March 29, 2009, 05:15:58 pm »
hmm.. that shows it is getting fuel. sounds like Gp's not coming on for long enough or at all
is it puffing white smoke?
Reply #6March 29, 2009, 05:17:33 pm
jettabrendan
  • 198
timing
« Reply #6 on: March 29, 2009, 05:17:33 pm »
yeah sure is, and i dont have the exhaust donut hooked up so its puffing out of the engine bay lol.
Reply #7March 29, 2009, 05:18:25 pm
timing
« Reply #7 on: March 29, 2009, 05:18:25 pm »
well, if your battery is good enough you could try and keep cranking in 15 second bursts until it fires. Work up cyl temps by cranking.
Reply #8March 29, 2009, 05:18:41 pm
jettabrendan
  • 198
timing
« Reply #8 on: March 29, 2009, 05:18:41 pm »
its still cold out and i dont think the block heater works, i filled it with coolant and have it plugged in right now to see. I dont think the plugs are working at all or else it would have fired, it isnt even firing at all.
Reply #9March 29, 2009, 05:19:37 pm
jettabrendan
  • 198
timing
« Reply #9 on: March 29, 2009, 05:19:37 pm »
i have been doing that since i got it together 5 days ago lol
Reply #10March 29, 2009, 05:21:48 pm
timing
« Reply #10 on: March 29, 2009, 05:21:48 pm »
***e.. this could be a different animal :(
does it feel like its going to catch at all?
Reply #11March 29, 2009, 05:29:36 pm
jettabrendan
  • 198
timing
« Reply #11 on: March 29, 2009, 05:29:36 pm »
nope, it just cranks. it ran before i changed the head gasket, i personally think that theres something wrong with the glow plugs cause my other jetta starts up no prob and it has a few bad plugs. the yellow led stays lit for like a minute.
Reply #12March 29, 2009, 05:31:37 pm
timing
« Reply #12 on: March 29, 2009, 05:31:37 pm »
how well do you know these cars? you did a Hg so you must kno alot lol.
Do you know what i mean when I say to manually jump the GP buss wire with a jumper cable hooked up to the + battery terminal?
Try that, if it starts then, it may be your GP controller. does your LED come on now????
Reply #13March 29, 2009, 05:32:30 pm
Rabbit TD
  • 840
timing
« Reply #13 on: March 29, 2009, 05:32:30 pm »
If you are sure it's timed right mechanicly then I would try advancing like you said a little at a time till it starts but wait till it completely warms up after driving before you do your final pump timing.  I had to take my T/D pump off because of leaks and put the N/A one back on but I have rebuilt 155 injectors on it so I went from 1.0 to 1.10 and then to 1.15 today with the gauge and it's right now just like the old N/A motor when it was at 1.0.  Just don't go over 1/8-1/4 at a time and don't try to get it real smooth on a cold or even cool motor and they cool off fast.
Reply #14March 29, 2009, 05:32:43 pm
jettabrendan
  • 198
timing
« Reply #14 on: March 29, 2009, 05:32:43 pm »
done it, i allready changed my gp relay too from another car, didnt make a difference.
