Author Topic: head gasket with 1mm over bore  (Read 2415 times)
March 26, 2009, 05:36:59 pm
thomcat
  • 20
« on: March 26, 2009, 05:36:59 pm »
Well I got my freshly faced pistons back from the machine shop, assembled the short block, then started looking at my 1.6 head gasket fit.
Its close to the pistons , I wouldnt worry if it had alighnment dowels to hold it it place . But without them it can get a little close to the pistons.
 The engine is bored 1mm over, 1.6 na mech. Do I have anything to worry about? Any suggestions not involving spending a bunch of money too center the head gasket? I usualy use a little sealer despite the victor reins suggestion not too. but that wont help me with this prob lol.
Reply #1March 26, 2009, 05:42:45 pm
truckinwagen
  • 1895
« Reply #1 on: March 26, 2009, 05:42:45 pm »
if you have a pair of the old head bolts you can hack the head off of them, cut a slot(so you can unscrew them with a flathead scewdriver) and use them as alignment dowels.
just screw them in, put the head on, install the rest of the headbolts, remove the two with a screwdriver and magnet, and put in the final two bolts.
or you could buy a set of studs :D
83 Opel Kadett Diesel
Reply #2March 26, 2009, 05:49:10 pm
thomcat
  • 20
« Reply #2 on: March 26, 2009, 05:49:10 pm »
Im running studs; I think ill back two of them out slightly to expose the  larger diameter threaded part. put the head on, snug it down. then run the studs back in . Sound like a plan?
Reply #3March 26, 2009, 05:50:36 pm
truckinwagen
  • 1895
« Reply #3 on: March 26, 2009, 05:50:36 pm »
sounds good to me, I wasnt sure if you were running studs or not.
yeah, since the studs can be tightened down after the head is on that should work good
Reply #4March 26, 2009, 05:56:49 pm
Rabbit TD
  • 840
« Reply #4 on: March 26, 2009, 05:56:49 pm »
If you are a little concerned about the gasket covering the bore just have piston 1 and 4 at TDC and when you drop the gasket on you will know it is clearing the bores.
Reply #5March 26, 2009, 07:44:25 pm
« Reply #5 on: March 26, 2009, 07:44:25 pm »
AFAIK the gaskets are sized in such a way as to handle standard overbores... and I've never seen "overbore" gaskets available... so you're probably good to go.
Reply #6March 26, 2009, 10:31:39 pm
  • 2926
« Reply #6 on: March 26, 2009, 10:31:39 pm »
I pulled a head off and found the piston was smashing the gasket.
 Looked like it had been doing this for a long time. I pulled the head because of a leaking headgasket.
 Nowadays I set a headgasket in place and see how the edges line up before I set the head on it,..
 then check the edges before I bolt it down tight.
Reply #7March 27, 2009, 08:37:08 am
« Reply #7 on: March 27, 2009, 08:37:08 am »
Quote from: "fatmobile"
1st time I've ever heard of that happeneing.
