Author Topic: Head gasket  (Read 4195 times)
March 25, 2009, 10:35:52 am
davidmccasland
  • 6
Head gasket
« on: March 25, 2009, 10:35:52 am »
so i just bought a 1981 vw rabbit 1.6 na and after i changed the coolant i noticed that coolant was seeping from the head gasket... how hard is it to change on that engine? it doesnt seem that bad its really small and right in front of you, as long as its not warped and cracked, also which gasket do i order the 2 notch or 3?
Reply #1March 25, 2009, 11:51:39 am
96jetta
Head gasket
« Reply #1 on: March 25, 2009, 11:51:39 am »
the curent guasket should still have the holes it in. there is a small part of the guasket sticking out in behind the injection pump
Reply #2March 25, 2009, 03:59:06 pm
gigaz2
  • 626
Head gasket
« Reply #2 on: March 25, 2009, 03:59:06 pm »
really easy to change the HG on a NA engine, on the TD the hardest part are the turbo connections, witch you don't need to worry about :D
you have to measure piston protrusion to select the HG, a set of feeler gauges and your set.
you could just slap a 3 notch in there, but when you have trouble starting it, rough idle and poor mileage you will regret that decision
Reply #3March 25, 2009, 04:35:06 pm
Rabbit TD
  • 840
Head gasket
« Reply #3 on: March 25, 2009, 04:35:06 pm »
There is a tab sticking out on the gasket in front which is probably covered with grime, it has either holes or notches which indicate which one to get.  If it's a 2 I'd probably just go get a 2 but if it's a 3 I think I'd measure first.  It's probably been changed before and lots of times shops just put a 3 on instead of measuring just to stay on the safe side.  Most of them from the factory were 2's to begin with.
Reply #4March 25, 2009, 10:36:15 pm
79rabbit4dr
Head gasket
« Reply #4 on: March 25, 2009, 10:36:15 pm »
search is your friend.
http://www.vwdiesel.net/forum/index.php?topic=17027.0
this has pictures, measurements for protrusion, etc.
p.s. please add your location in your profile, you might have a neighbor that could help  :D
« Last Edit: May 28, 2009, 08:43:51 am by 79rabbit4dr »
Reply #5March 26, 2009, 07:31:54 am
davidmccasland
  • 6
Head gasket
« Reply #5 on: March 26, 2009, 07:31:54 am »
Im a student in Durango Co
Reply #6April 01, 2009, 11:02:08 am
davidmccasland
  • 6
Head gasket
« Reply #6 on: April 01, 2009, 11:02:08 am »
so where the upper radiator hose is attached to the engine the little aluminum piece is leaking, when i replace the gasket to i use sealant or not
another thing where the vacuum line goes from the engine there is another tube that does not go to anything i was curious what that was for? testing vacuum pressure?
Reply #7April 03, 2009, 04:28:29 pm
96jetta
Head gasket
« Reply #7 on: April 03, 2009, 04:28:29 pm »
is either end of the line connected to any thing? what is the line made of?
Reply #8April 03, 2009, 04:31:17 pm
Head gasket
« Reply #8 on: April 03, 2009, 04:31:17 pm »
Quote from: "davidmccasland"
This is sealed with a rubber o-ring.... no sealant required
This could be a lot of things... best bet is to post up a picture or two if you can.  See the FAQ if you need help figuring out how to post pictures... there's a good write-up there.
Reply #9April 03, 2009, 05:41:34 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
Head gasket
« Reply #9 on: April 03, 2009, 05:41:34 pm »
before you get too carred away(if you havent allready) re torque the bolts if there is no oil in the coolant or vice verse.. if its just leaking out of the side torquring should fix it. it did on my other jetta and its holding up just fine..
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #10April 03, 2009, 08:39:30 pm
  • 3468
    • McScrubbins Body Wash
Head gasket
« Reply #10 on: April 03, 2009, 08:39:30 pm »
Sometimes coolant will leak from the T at the head and you won't see it leak from there because you'll rarely look at it while it's running. The coolant will dribble down the head and sit on the HG bringing you to believe the HG is leaking.
While the car is running and up to temp. give the T on the head a little wiggle up and down.
Reply #11April 03, 2009, 10:31:39 pm
dieselweasel
  • 312
Head gasket
« Reply #11 on: April 03, 2009, 10:31:39 pm »
Quote from: "Smokey Eddy"
That's what I was going to say...I bet the HG isn't leaking, it's just coming from the water flange and running down to the HG.
Reply #12April 03, 2009, 11:14:04 pm
maxfax
  • 2126
Head gasket
« Reply #12 on: April 03, 2009, 11:14:04 pm »
x2 on it being the coolant neck..   I'd start there..  Good chance that the surface of the head and or the coolant neck are pitted a bit, a little RTV with the o-ring won't hurt (just don;t get crazy with it, thin coating!)
 Take some PB blaster (or equivelant) and soak the heck outta the bolts holding the neck to the head...  These little guys love to sieze in there and twist off..
If it does turn out to be your head gasket you have a 1981 which should have 11mm head bolts..  You can try retorqing these, but DO NOT OVER TORQUE THEM!.. You run a very high risk of cracking the block..  Actually you run a pretty high risk of cracking the block just by retorquing these to spec....   If by chance you end up replacing the head gasket, do a search on head studs!!! The whole cracking of the block issue will be explained...
Reply #13April 07, 2009, 02:54:11 pm
ccoxva
  • 15
Head gasket
« Reply #13 on: April 07, 2009, 02:54:11 pm »
I am having the same prob but my head has been resurfaced and checked for cracks and just reassembled. We just got it running and it has water sitting in the same spot on the gasket. Only gets wet when its been drove over about ten minutes. Glad you guys are on here I was gonna remove the head again.
Thanks Chris Cox.
89' VW Jetta diesel
Reply #14April 10, 2009, 12:56:27 pm
ccoxva
  • 15
Head gasket
« Reply #14 on: April 10, 2009, 12:56:27 pm »
What can I retourqe the head to and be safe???
89' VW Jetta diesel
