Author Topic: piston balancing  (Read 1947 times)
March 23, 2009, 06:28:27 pm
smoken u
  • 231
piston balancing
« on: March 23, 2009, 06:28:27 pm »
hi all, havent been on here for a while, life has been very busy as of late, but i am starting to finally get some progress going on my vw build up  :D  im looking to balance my pistons in the very near future ( i still have to clean then and what not and i havent weighed them yet) now ive never balanced pistons before and am not really sure where to grind the weight off from, i am assuming the inside of the crown but am not sure any help or advice would be greatly appreciated :) thanks
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
Reply #1March 23, 2009, 08:03:35 pm
piston balancing
« Reply #1 on: March 23, 2009, 08:03:35 pm »
have you weighed them? are they off by much?
Reply #2March 24, 2009, 05:00:43 am
arb
piston balancing
« Reply #2 on: March 24, 2009, 05:00:43 am »
When I worked at Federal Mogul's research lab, the testing showed the lower skirts were under the least stress.
So, I never remove material from the crown nor wrist pin bosses, but from the lowest part of the skirt.
Reply #3March 24, 2009, 08:29:19 am
smoken u
  • 231
piston balancing
« Reply #3 on: March 24, 2009, 08:29:19 am »
ok so the lower part of the skirt would be the best place to remove the wight from, adn no i havent weighed them yet, probably get around to dojing that on the weekeend if all goes well :), and at the same time i'll weight the connecting rods to see how much they can be balanced up as well.
