Author Topic: squeeky fanbelt  (Read 3181 times)
March 23, 2009, 01:34:41 pm
nogama3
  • 162
squeeky fanbelt
« on: March 23, 2009, 01:34:41 pm »
hi guys, i keep on getting a squeeky fanbelt. it has been changed 3 times in the last 18 months but returns to haunt me. why does this keep on happening and howcan i avoid this happening again? any preventative measures i can take?
Reply #1March 23, 2009, 01:54:27 pm
squeeky fanbelt
« Reply #1 on: March 23, 2009, 01:54:27 pm »
v-belt?  which one is squeaking???
Reply #2March 23, 2009, 02:25:51 pm
nogama3
  • 162
squeeky fanbelt
« Reply #2 on: March 23, 2009, 02:25:51 pm »
its the larger belt that squeels like a pig!
Reply #3March 23, 2009, 03:51:51 pm
squeeky fanbelt
« Reply #3 on: March 23, 2009, 03:51:51 pm »
Quote from: "nogama3"
so i assume you have a 1.6 with a/c? or no? did you replace with a Conti belt?  mine was hard to put on.. i had to actually use a screw driver and turn the engine by hand to zip it on  :lol: AND to take it off.  no squeals, and the alternator adjustment was perfect.  it could be badly worn pulley's, but thats doubtful.  the pulleys usually wear from excessive heat (from slipping)
i would also recommend that you look and make sure that all bolts are there, because my alternator bolt fell out once and then the belt would squeal like a pig too!  :lol: and not charge  :(
Reply #4March 24, 2009, 01:56:59 am
nogama3
  • 162
squeeky fanbelt
« Reply #4 on: March 24, 2009, 01:56:59 am »
hi, my motor is a 1.9 aaz enginee with no a/c and added intercooler.
the pulleys are all fine and none of the bolts appear to be missing or loose.
it mainly happens at the wrong time - when its most embarrising for me!
Reply #5March 24, 2009, 05:15:22 am
arb
squeeky fanbelt
« Reply #5 on: March 24, 2009, 05:15:22 am »
Ddi you verify all the pulley's are in the same plane with no wabble ? If the alternator is a little to one side or the other, they will not be in plane and they will make noise. I assume the tension is correct and the alternator can't slip under high load ?
Reply #6March 24, 2009, 05:43:42 am
nogama3
  • 162
squeeky fanbelt
« Reply #6 on: March 24, 2009, 05:43:42 am »
well, my old man did all the work and he is a little annoyed at me for changing the belts so many times. i'll have to check the belts and make sure theres no crap on them to see if that makes a difference.
Reply #7March 24, 2009, 05:57:47 am
arb
squeeky fanbelt
« Reply #7 on: March 24, 2009, 05:57:47 am »
Hang in there man, my experiance has been that squeeky belts tend to depart the vehicle when you least want it... so I think your changing them is $10 well spent.  Find the root cause and you'll be good.
Reply #8March 24, 2009, 08:27:02 am
nogama3
  • 162
squeeky fanbelt
« Reply #8 on: March 24, 2009, 08:27:02 am »
thanks for the advice fella's
Reply #9March 25, 2009, 03:16:40 am
regcheeseman
  • 714
squeeky fanbelt
« Reply #9 on: March 25, 2009, 03:16:40 am »
Mine squeals too - same setup.
New belt helped for about a week.
Then I overode the auto-tensioner on the altenator by using a lump of wood between engine and alt as a lever to add extra tension before tightening bolts.
Still squeals - and I'm suspecting the nose bearing in the alt - especially now as some clown has over tensioned the belt  :lol:
Reply #10March 25, 2009, 11:52:16 am
bert
  • 423
squeeky fanbelt
« Reply #10 on: March 25, 2009, 11:52:16 am »
what make of belt you using? im using a gates micro v and its been on since the build,no squeaks,and the tension is not overly tight,if you overtighten the belt it will wear the water pump bearings and the alternator bearings,ive got a clutch pulley on my alternator too,stops the belt bounce  :wink:
Bert
Reply #11March 26, 2009, 08:09:59 am
nogama3
  • 162
squeeky fanbelt
« Reply #11 on: March 26, 2009, 08:09:59 am »
Hi Bert,
how are you? aint heard of you for ages.
might check the make of belt, just in case it is a cheapy one causing me all this grief.
old man aint gonna be happy as it is a bit of a pain in the rectum to do - time wise.
Reply #12March 26, 2009, 11:29:06 am
bert
  • 423
squeeky fanbelt
« Reply #12 on: March 26, 2009, 11:29:06 am »
hey mate,im sound you ok? im going to santa pod sunday if its dry,the mk1 golf club has a stand and the one geezer is going up the strip in his bert modified turbo diesel aaz  :twisted:
Bert
Reply #13March 26, 2009, 01:32:10 pm
nogama3
  • 162
squeeky fanbelt
« Reply #13 on: March 26, 2009, 01:32:10 pm »
shame i cant make it. hope the weathers good for you. make sure you take some pics/vids of the diesel.
sal
