Author Topic: Horrible Mileage.....Please Help  (Read 3540 times)
Reply #15March 24, 2009, 11:37:14 am
« Reply #15 on: March 24, 2009, 11:37:14 am »
Quote from: "NoSurrenderAG"
I got new nozzles but not injectors.. is that good enough?
if you set the breaking pressure, yes.  and if you don't, at least you won't have to worry about burning a hole through your piston(s)  :lol:
Quote from: "theman53"
I also forgot that when I replaced my injectors things got tremendously better in the MPG department. If it has been 50-100 thousand miles you might try that too if the diesel, oil, and filters change doesn't help. Injectors do wear out over time and I think that the bentley says replace them in the range above.
running a lubricity additive and using a 1 micron filter will greatly increase the nozzle life  :wink:
Reply #16March 24, 2009, 01:38:23 pm
Golf/Jetta
  • 102
« Reply #16 on: March 24, 2009, 01:38:23 pm »
lubricity additive (WVO, VO, ATF,)
anything thicker then diesel (oil) should be fine due to the season changing but don't add to much. just to drown out the (Winter fuel)Kerosene. it will change the internal pressure of the IP... keep it clean
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
Reply #17March 24, 2009, 02:06:07 pm
allsierra123
« Reply #17 on: March 24, 2009, 02:06:07 pm »
winter fuel gives horrible mileage around here.
