Author Topic: TDI intercooler on TD ?  (Read 1970 times)
March 21, 2009, 12:55:54 pm
ELVIS
  • 51
« on: March 21, 2009, 12:55:54 pm »
Bought one off fleabay - £22.50 with all pipes including delivery!
     I think i know where it mounts but just want to confirm it.Under the battery tray area there are three holes on a vertical plate coming down from the chassis leg. The three holes have elongated slots on them at the 6 o clock position.
 I am guessing this is where the IC mounting bracket goes ?
    However , the mounting bracket only lines up with 2 of them.Is this because the tdi body is slightly different ?
     In my mind it is the only place it will fit, ideas/pics ?
Reply #1March 21, 2009, 03:00:53 pm
nogama3
  • 162
« Reply #1 on: March 21, 2009, 03:00:53 pm »
hi, i fitted a tdi intercooler onto my mk3 golf td using the bracket. you may want to remove the two/three plastic gromets that hold the arch liner for ease of access.
Reply #2March 21, 2009, 03:40:38 pm
ELVIS
  • 51
« Reply #2 on: March 21, 2009, 03:40:38 pm »
Cheers chap! Did you find on the vertical mounting face of the bracket the two top bolts (one in each top corner of the bracket ) mounted ok , the third which is lower and sited in from the side didnt appear to line up.Is this standard ? Is the TDi + Td body slightly different ?
Reply #3March 22, 2009, 02:15:32 pm
nogama3
  • 162
« Reply #3 on: March 22, 2009, 02:15:32 pm »
from what i can remember, the bracket fitted fine, two bolts at top one at bottom. mines an aaz on a 96plate and i didnt have no issues. i did have custom pipe work done as the original pipes didnt really work out too well.
Reply #4March 22, 2009, 02:19:38 pm
nogama3
  • 162
« Reply #4 on: March 22, 2009, 02:19:38 pm »
