Author Topic: What IP is this?  (Read 4981 times)
March 20, 2009, 02:06:40 pm
autoholic
What IP is this?
« on: March 20, 2009, 02:06:40 pm »
Well, 1.6TD #2 is complete so I'll have the samurai back in action soon. This time I used ARPs, high volume oil pump, pan baffle, in addition to everything else that is new.
I still need to figure out what to do about an IP. I gave my rebuilt IP to my friend and am stuck with his problem IP that I had apart several times, nothing seems to be wrong, sick of working on it.
I found these IP's on ebay, I bought it brand new for 160. The shaft is larger and it has no advance lever, but the advance set up will accept the lever. The IP is for an Onan Generator. The only diesel engine I have seen in an Onan generator is an cummins, Onan or lister petter (the Onan and Lister's use unit injectors), none ever had VW industrial that I am aware ( I used to work for an Onan distributor). I was hoping it was a 4BT pump, but according to the #'s it is a 9mm and I think the 4bt's are 12mm?
Do you think I can make this work for my 1.6D (NA motor w/ turbo) I'm not looking for big power, just a strong, reliable runner.
Here are the numbers:
NEW OLD STOCK from Onan generator surplus.
VE PUMP
Bosch diesel fuel injection pump.  Name plate is stamped:  Made in Germany specifically for Onan.
NR. 0 460 494 213
VE     R     315
147-0462-20
011 (circled)  752 08575
Any help appreciated, I think more are still available if anyone is interested.
~Mark
Reply #1March 20, 2009, 02:26:26 pm
rallydiesel
  • 1880
What IP is this?
« Reply #1 on: March 20, 2009, 02:26:26 pm »
Can you post some pics? I think I would cut my losses and get a 1.6TD pump. Does it start at all? Does it draw fuel? There's going to be a lot of questions for an unknown application pump. I think someone like Giles could eventually set it up to run a VW engine but I think it would be cheaper to just find a used 1.6TD pump.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2March 20, 2009, 02:29:50 pm
autoholic
What IP is this?
« Reply #2 on: March 20, 2009, 02:29:50 pm »
What confuses me is that it has the 20MM shaft size, but the # says it is a 9mm pump. I thought all 20mm shafts would be 10mm and up?. Maybe I am looking at an inaccurate chart. I bet this is simply the same pump as 1.9 Vw industrial, in some odd Onan application.
What do you think, good deal for 160? it is brand spanking new in factory packaging.
Reply #3March 20, 2009, 02:32:10 pm
autoholic
What IP is this?
« Reply #3 on: March 20, 2009, 02:32:10 pm »
Its not installed yet. I would go with a 1.6TD pump, but they are not so easy to find. I'll be picking up a TD Quantum soon, which I can rob the pump from, but I'd like to leave the car alone. I just thought for 160 it was worth grabbing this mystery pump since it is brand new.
I'll pull the top off and compare throttle linkage/gov for starters.
 I think they are still on ebay (search VE injection pump)
Reply #4March 20, 2009, 02:39:51 pm
Reply #5March 20, 2009, 03:03:57 pm
autoholic
What IP is this?
« Reply #5 on: March 20, 2009, 03:03:57 pm »
Quote from: "autoholic"
OK, I dug around some more and found that the larger shaft can be a 9mm (and that 17MM shafts can be 10-12MM) so I guess that is what it is, a 9MM pump w/ 20MM shaft.
That thing is a bargain for 160!
Reply #6March 20, 2009, 03:33:15 pm
Hey
  • 339
What IP is this?
« Reply #6 on: March 20, 2009, 03:33:15 pm »
Also check if this is a short shaft. If it is a short shaft you will have difficulty fitting it. It is possible but not simple.
tdi 20mm shaft have # 2 466 100 029. This pump have # 1 466 100 318 shaft.
This is the same shaft used on 5.9L,  ford 6BTAA engine from 1998 engine. Are those pump short shaft?
Reply #7March 20, 2009, 03:52:09 pm
subsonic
  • 1836
What IP is this?
« Reply #7 on: March 20, 2009, 03:52:09 pm »
0 460 494 213 =  VE4 / 9F 1000 R315
9mm plunger
Mechanical
1000 = upper pump nominal speed (1/2 of engine rpm)
R = clockwise
315 = type code
Reply #8March 20, 2009, 04:59:57 pm
autoholic
What IP is this?
« Reply #8 on: March 20, 2009, 04:59:57 pm »
Interesting, thanks.
I think it is a long shaft, seems the same as my other pumps (they're not in front of me right at the moment though)
I guess I need a Tdi pully? I'm anxious to see the linkage and gov,
changing the linkage (and doing gov mod) will not be a problem, but I am not sure how to actually adjust the Gov. On other VE pumps i have worked with I just set it to where it was originally. I guess i can compare the adjustment to another pump. I'll need to spend more time researching old posts.
So at this point I'll be using a 9MM NA pump (turned up a bit of course), a 1.9 camplate, gov mod, new 155bar TD injectors, adjustable boost reg (so I can turn it down on long hills if I need) The engine is a rebuilt NA 1.6motor with turbo. (the old motor was completely rebuilt running great, then I cracked the block when retorqing the head at under 500 miles)
Think this will work OK? I'm looking for a little more power then stock, but really want longevity. This thing is pretty much trail rig only.
Reply #9March 24, 2009, 02:21:28 pm
autoholic
What IP is this?
« Reply #9 on: March 24, 2009, 02:21:28 pm »
I removed the top and found that this industrial IP simply had a spring on a lever for the throttle linkage. I replaced this setup with the regular automotive type (and did gov mod) which was simple enough. I had to use the throttle shaft, return springs and lever from the automotive IP also, which was a shame since the splines on my old pump throttle shaft are kind of beat up. All went together fine though, job was simple enough except setting the lever and springs is always my least favorite part of working on these!
 I think it'll work fine, I just need a pully and to time it. The engine is back in so I'm getting close now.
One thing I did not decide to change was the advance piston, so I will not have an advance lever (since the piston that is in it has no provision for the lever). I never really use it anyway, I'll just make sure I time it right and run it. I can always change this later if I want.
The Spring is Blue, and I left the shims as they are, seems a bit lighter then the automotive spring.
So the length is the same as the other pumps I have, it is not shorter. does this mean an AAZ or early Tdi pully will fit?
We'll see how it works soon enough. For 160 I'm still happy with the purchase of this pump. Sure is nicer then all the old junk I have.
Also, I took the other pump apart yet again since I was going to use the 1.9 camplate. I was looking at the camplate and noticed that the max lift on the highpoints of the plate are NOT 90* apart. I am wondering now if the IP problem I was having with my friends pump was a defective cam plate?!?!?! That'd be a B! I had that thing in and out so many times!
I'm gonna measure it out/compare it to another to determine if this plate is defective.
Reply #10March 24, 2009, 05:50:51 pm
autoholic
What IP is this?
« Reply #10 on: March 24, 2009, 05:50:51 pm »
Quote from: "libbybapa"
It is the short shaft.  The TDI sprocket will not work, in fact there is not any stock sprocket that will work.  Easiest is probably to have a 1.6 sprocket machined to accept the larger shaft.  You will also need to swap in a 1.6 governor spring assembly, control collar lever assembly and fit the cold start.  IMO it's a great deal for someone wanting to make a VW genset, but the amount of modification necessary for auto application makes it unappealing to me.
Andrew
Why do you say its the short shaft? it's the same length as the 17MM pumps I have. I'm not sure what pulley to buy.
Reply #11March 24, 2009, 05:51:52 pm
autoholic
What IP is this?
« Reply #11 on: March 24, 2009, 05:51:52 pm »
Andrew
Or maybe the 20MM pumps should have a longer shaft then the 17MM?
Reply #12March 24, 2009, 05:55:27 pm
truckinwagen
  • 1895
What IP is this?
« Reply #12 on: March 24, 2009, 05:55:27 pm »
yeah, with my 4BTA pump (short 20mm shaft) I had to get a local shop bore out the small shaft pulley.
it cost $160 for the shop to do it, and many shops wont even try.
83 Opel Kadett Diesel
Reply #13March 24, 2009, 06:06:17 pm
autoholic
What IP is this?
« Reply #13 on: March 24, 2009, 06:06:17 pm »
Well that sucks, I thought that since the length was the same on this pump  as my other pumps, this would not be a "short shaft" So The 20MM shaft pumps should be longer then the 17MM shaft pumps to use a factory sprocket, OK.
I did read through the FAQ's regarding this, but it was not clear to me that the 2oMM shafts should be longer than the 17MM to use a factory sprocket, that is; the short shaft 20mm is the same length as the regular 17MM.
Not sure what I'll do now, maybe go back to the other pump, since it seems that the problem with that one was simply that !%!%!$@##!@$%!% cheopo cam plate!
Reply #14March 24, 2009, 07:37:44 pm
autoholic
What IP is this?
« Reply #14 on: March 24, 2009, 07:37:44 pm »
OK, so I'm hunting down a MK4 pully/hub set up, seems like the only practical option. If anyone knows WTB please advise. Thanks.
