Author Topic: Power engine build do I use the AAZ or 1.6 GTD block  (Read 11380 times)
Reply #15March 21, 2009, 02:50:19 pm
Baixo
« Reply #15 on: March 21, 2009, 02:50:19 pm »
i say AAZ
all the time/effort you would put into a 1.6 is better served to a AAZ.
AAZ w/ extensive head work, with a gt28rs ball bearing turbo will give you a nice broad power band, and with a giles pump i think 4900-5000 should be attainable
just my .02
Reply #16March 22, 2009, 04:50:04 am
stewardc
« Reply #16 on: March 22, 2009, 04:50:04 am »
I looked at them all, and went AAZ. The bottom end grunt is truly spectacular for daily driving and , with a 2-stage boost controller, I get top end when needed. 10 psi daily and 25 psi when needed. :shock:  :D  :D  :D  :D
Reply #17March 22, 2009, 09:56:42 am
« Reply #17 on: March 22, 2009, 09:56:42 am »
well, ive got an ancient N/A 1.5 thats got 22 psi going to it with a fiber gasket. it has quite a bit of power. over 100 hp for sure, cause it smokes hondas and toyotas too good to be very weak. and i wind that thing to the bolts, and nothing has ever let go. except a block, but we wont go there, it took 37psi to do that.
Reply #18March 23, 2009, 09:43:44 am
13ad13oy
  • 8
« Reply #18 on: March 23, 2009, 09:43:44 am »
Hi Reg,
What you thinking of for target power? Also where will you source your VNT? Will be watching your build up   :mrgreen:
Al
89 Caddy Truck
Reply #19July 06, 2009, 03:42:42 am
regcheeseman
  • 714
Re: Power engine build do I use the AAZ or 1.6 GTD block
« Reply #19 on: July 06, 2009, 03:42:42 am »
Having driven the 1.9 and the 1.6 in tuned form now, I can confirm the 1.9 is a lifeless dull slog of an engine.
1.6 it is.
Reply #20July 06, 2009, 12:32:07 pm
Zulfiqar
  • 254
« Reply #20 on: July 06, 2009, 12:32:07 pm »
having driven a AAZ sans turbo (dont ask how) it was a dull dead dog on cocaine..
build a 1.6 wiz what ze germans call a gross turbolader mit VNT a 10mm peugoet pump head SD274 nozzles @155 bar and a free exhaust, couple that to a GTI gearbox and you are in business
Diesel IS the future
Reply #21July 07, 2009, 01:19:07 am
tSoG-84bit
  • 188
« Reply #21 on: July 07, 2009, 01:19:07 am »
hmmmm, I have 1.5 internals, a 1.6 block... who has a 1.9 head for me? can you run a 1.9 with mechanical lifters?
84bit 1.6na
Engine died, pulling it apart, putting something new in it's place.
Reply #22July 07, 2009, 05:04:53 am
« Reply #22 on: July 07, 2009, 05:04:53 am »
yes I believe you can. I think sourkraut on here is doing it.
Reply #23July 07, 2009, 08:54:34 am
« Reply #23 on: July 07, 2009, 08:54:34 am »
1.9 head flows better than the 1.6 head.  It has larger intake/exhaust ports.  They're a different shape than the 1.6 ports though (D-shaped) so you should use 1.9 manifolds (intake especially)...
I believe the 1.9 hydro head is a direct swap for the 1.6 hydro head, so anything you'd do to use a hydro head on a mech block applies.
Reply #24July 07, 2009, 12:40:39 pm
ktownboostn
  • 31
« Reply #24 on: July 07, 2009, 12:40:39 pm »
1.6 Block. 1.9 AAZ Head. Hands down Solid Set up with Great Power.
2001 VW Jetta 24v VR6 - Rally Car
1990 VW Jetta AAZ/MF - Daily coal roller
1986 VW Cabriolet 12v VR6 - Project car
Reply #25July 07, 2009, 05:12:57 pm
« Reply #25 on: July 07, 2009, 05:12:57 pm »
1.9 exhaust ports are identical to the 1.6
Reply #26July 07, 2009, 11:52:15 pm
Syncroincity
  • 727
« Reply #26 on: July 07, 2009, 11:52:15 pm »
What kind of work on the aaz?  Head porting if done correctly will give you the ability to have great gains.  The done correctly is the important part.  We dont have too many people on this side of the pond that are knowledgable on serious vw diesel head porting. How about over there?
Can you expound on "correctly done", please? My AAZ head is just off & I'd like to have some port work done to it... I haven't looked for a machine shop yet, but there's a VW shop I trust in Long Island & I'm going to ask them for a recommendation.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #27July 08, 2009, 09:05:05 pm
« Reply #27 on: July 08, 2009, 09:05:05 pm »
What about this in an N/a setup?
Reply #28July 08, 2009, 09:44:29 pm
« Reply #28 on: July 08, 2009, 09:44:29 pm »
So if i were to add say a K03 while adding the AAZ head and a Giles pump.. then it would be worth it? (Thats what i plan on doing in the future)
I wouldn't want it.  The 1.9 head will make starting hard with it's lower compression.  Without taking advantage of boost, it wouldn't be worth it.
Reply #29July 09, 2009, 08:44:56 am
« Reply #29 on: July 09, 2009, 08:44:56 am »
ok, so from what i have picked up, it is not important to mirror finish the ports. and also you dont really want to re shape the ports at all. basically you just want to clean up the casting flaws out of the port. smooth it down a bit. maybe open it up a little, but stay away from reshaping unless you are SUPER CONFIDENT with a dremel. all ive ever used was a dremel with a flexy shaft and one of those small sanding drums. i actually could feel the difference in my tired 1.6 when i cleaned up the ports.
