Author Topic: fast times in the hammertown  (Read 13547 times)
June 15, 2004, 12:20:22 am
Dr. Diesel
  • 1341
« on: June 15, 2004, 12:20:22 am »
Couple of short stories.
Yesterday I found myself at a red light next to some US musclecar. It almost looked like a pinto, but had a cammed (by the sound) v8 of some sort, huge rear tires and dual exhaust. Some punk kid driving it. He was torking it at the lights, looking at me. I ignored him. Lights turned green, and he was on and off the gas like an old pedal organ. Next light was red, we stopped. I gave a little blip of the throttle. That really wound him up. An A2 golf showed up too. Lights turned, and I was out of there like a shot. I was deep into 4th before slowing for the next light. The whole time I could hear the v8 roaring, but couldn't see him. (didn't want to look BACK while ripping along)
He turned off a side street rather than stop next to me. Sucker.
Today, my friend and took off out of my shop's parking lot together, him leading. He's driving a new GTI 1.8T. We turned down a sidestreet and both gunned it. In the time it took my turbo to spool up he'd pulled ahead 2 carlengths. After that, for 2nd and 3rd I was stuck to him like glue. In 4th, i started to catch up, though he might have let off at that point.
Not bad for an old kerosene-burning rattlebox!
Reply #1June 15, 2004, 11:14:27 am
BlackTieTD
  • 1512
« Reply #1 on: June 15, 2004, 11:14:27 am »
..and afterwards, don't you wish they could hear you yelling "and its a DIESEL suckaaaa!!!!!"  :lol: nice.
Reply #2June 15, 2004, 11:28:58 am
TDIMeister
  • 284
« Reply #2 on: June 15, 2004, 11:28:58 am »
I'm really looking forward to meeting both of your and check out your über-quick Diesels  :lol:
Hey, I've been trying to get in touch with Giles in the hopes that he could make it down as well, but I just got off the phone with Superior Fuel Injection and was told that Giles is on vacation until Friday, and I never got a reply to a PM I sent long ago...  :(
Reply #3June 15, 2004, 11:31:14 am
Dr. Diesel
  • 1341
« Reply #3 on: June 15, 2004, 11:31:14 am »
yeah, he's hopefully not drinking the water in mexico. Probably hasn't seen a pm yet.
I'm eagerly awaiting his return myself.
Reply #4June 15, 2004, 11:41:59 am
BlackTieTD
  • 1512
« Reply #4 on: June 15, 2004, 11:41:59 am »
i wouldn't say uber-quick... but its not a slug thats for sure.
i need bigger exhaust and the fun begins. bryson's car can move!  :D
looking forward to meeting all you diesel crazies myself!
Reply #5June 15, 2004, 12:25:08 pm
type53b_gtd
  • 118
    • http://scirocco.cs.uoguelph.ca/gtd/
« Reply #5 on: June 15, 2004, 12:25:08 pm »
Can we get some details on your ride, Dr. Diesel?
Drew
Reply #6June 15, 2004, 12:58:43 pm
Dr. Diesel
  • 1341
« Reply #6 on: June 15, 2004, 12:58:43 pm »
the basics:
A2 jetta 2720 lbs driver, 1/2 tank
1.6L 30 psi unintercooled w/ GILES pump
3rd gen downpipe, 2.5" exhaust
Reply #7June 15, 2004, 01:14:17 pm
type53b_gtd
  • 118
« Reply #7 on: June 15, 2004, 01:14:17 pm »
Quote from: "Dr. Diesel"
OK, two questions -
1) what are you using for a head gasket, titaniium?
2) what in blue blazes is a GILES pump ? :)
Reply #8June 15, 2004, 01:29:24 pm
Dr. Diesel
  • 1341
« Reply #8 on: June 15, 2004, 01:29:24 pm »
stock OE headgasket & bolts.
Do a search on here for 'Giles' and 'superior fuel injection'.
He's the dude who modifies bosch VE pumps so that a diesel can actually make some power. (you're wasting your time without one, IMO)
Reply #9June 16, 2004, 07:58:10 am
type53b_gtd
  • 118
« Reply #9 on: June 16, 2004, 07:58:10 am »
Impressive... :)  I have some low spots on my deck, and more than 20 seconds at 14psi at the manifold and I see coolant where it shouldn't be... :)  Of course, at those manifold pressures the K03 is in the "danger zone" anyways.
Well, that search string yielded one post - yours... :)  However, I was able to find a few threads that referenced Giles and governor modifications - which made for interesting reading.  Methinks I'll pop the cover on a scrap pump and have a look at what is involved in the "governor" mod - but it'll have to wait until the Scirocco isn't on daily driver duty... :)
Note - the Bosch Diesel Injection book I have refers to an "idle and maximum speed" governor (http://scirocco.cs.uoguelph.ca/gtd/bosch-ve/governor_4.jpg) which sounds like the desired effect of this mod (compared to the variable speed governor:
http://scirocco.cs.uoguelph.ca/gtd/bosch-ve/governor_2.jpg and http://scirocco.cs.uoguelph.ca/gtd/bosch-ve/governor_3jpg)
Does the "Giles" treatment entaiil further modifications, like upgraded plunger size, timing advance etc?
Drew
Reply #10June 16, 2004, 08:30:07 am
BlackTieTD
  • 1512
« Reply #10 on: June 16, 2004, 08:30:07 am »
plunger yes. timing i'm not sure. giles is the pump man, when i get everything setup properly i'll be sending a pump to superior, can't wait!  :D
Reply #11June 16, 2004, 11:05:49 am
Dr. Diesel
  • 1341
« Reply #11 on: June 16, 2004, 11:05:49 am »
Plunger yes, if you want it. But an upgrade to a 1.9L camplate will yield more available fuel than you'll likely ever need.  At 30 psi, I still have more available.  There's much more to a Giles pump than simply replacing the max speed govenor. Best thing is to call him. He'll be back from vacation on monday.
Reply #12June 16, 2004, 11:22:46 am
type53b_gtd
  • 118
« Reply #12 on: June 16, 2004, 11:22:46 am »
Would it be easier to install the 1.9 pump (with appropriate modifications, of course) and injectors on the 1.6?
At the kinds of rpms that I've seen discussed here, you don't need more fuel, you need a time warp inside your combustion chambers so what's jammed in there has more time to burn.  Seeings that's pretty unlikely, the next best thing would be fuel that burns faster than diesel does.  Diesel does have more energy than gasoline, but it takes longer to release it too!
Are we discussing trade secrets that should not be posted at risk of angering Giles, or is he willing to discuss the nature of these mofifications extensively?
Drew
Reply #13June 16, 2004, 05:50:14 pm
Dr. Diesel
  • 1341
« Reply #13 on: June 16, 2004, 05:50:14 pm »
Part of the Giles package includes mods to the advance mechanism. In stock form, it stops advancing a lot earlier than you'd expect. (i don't remember rpm numbers now)
Most, if not all the mods he does were discussed at one time or another, though mostly in the old forum. Since then I've become good friends with him, and out of respect for him, suggest anyone interested feel free in calling him directly to discuss mods. Nobody's trying to keep secrets here, which is why i'm always saying CALL GILES.
Here's his number again:
Giles @ superior fuel injection 905-475-1122
Markham Ontario
The 1.9L pump requires use of the 1.9L engine's pump mount bracket, which won't fit on the the 1.6L engine.
My engine still pulls hard at an estimated 6000 rpm (tach doesn't go that high)
Reply #14June 17, 2004, 05:46:49 am
BlackTieTD
  • 1512
« Reply #14 on: June 17, 2004, 05:46:49 am »
i don't think that 95% of us will ever need any more fueling than a pump like the one dr. diesel is running. i mean, 30psi and you should see the soot that car still blows!  :shock:
