Author Topic: NA injector lines with TD pump...  (Read 2150 times)
March 16, 2009, 07:52:26 pm
hamradio
  • 282
« on: March 16, 2009, 07:52:26 pm »
So,
Is there some quick solution to make one of the NA injector lines clear the TD pump, or should I just buy/find a td line?  If I could get about 1/4" more of clearance, I think it would be fine.  Can the line be bent at all, enough to be able to advance timing a little more?
Devan
Reply #1March 17, 2009, 02:43:27 pm
« Reply #1 on: March 17, 2009, 02:43:27 pm »
Purposely time the pump 1 tooth off and the pump will sit more forward and clear the line
Reply #2March 17, 2009, 04:12:13 pm
hamradio
  • 282
« Reply #2 on: March 17, 2009, 04:12:13 pm »
Awesome!  Thank you, Tyler!
