Author Topic: Vented Thermostats  (Read 2963 times)
March 15, 2009, 11:59:42 pm
Rabbit TD
  • 840
Vented Thermostats
« on: March 15, 2009, 11:59:42 pm »
Has anyone ever had any problems on our engines using the vented style thermostats, the ones with the little hole with a small loose fitting little pin type thing in them?  It seems like the things would lt coolant flow all the time .
Reply #1March 16, 2009, 06:03:21 am
Vented Thermostats
« Reply #1 on: March 16, 2009, 06:03:21 am »
They do let it flow all the time. The idea is that it will let air out and the hole is usually about 1/16" so it isn't a huge flow of coolant. Plus it has the brass piece to restrict it some more. When the H2O pump and pressure aren't working the brass piece is supposed to fall back into place as not to let the coolant flow back. I haven't used on on the diesel but have on my 400 Ford with great results.
Reply #2March 16, 2009, 07:03:08 am
red64chevelle
  • 67
Vented Thermostats
« Reply #2 on: March 16, 2009, 07:03:08 am »
I always use them on small block Chevy's.  In fact, if it does not have the hole, I'll drill a small one in it.  I find that the thermostat operates much smoother.
2003 Jetta GL TDI
1999 Beetle GLS TDI
1987 Cabby
1984 Jetta TD
1984 Rabbit GTI
1964 Malibu Convertible
Reply #3March 16, 2009, 09:38:56 am
Vented Thermostats
« Reply #3 on: March 16, 2009, 09:38:56 am »
I drill a hole in all my thermostats.
Reply #4March 16, 2009, 10:00:22 am
88jetta350
Vented Thermostats
« Reply #4 on: March 16, 2009, 10:00:22 am »
+1
I have done that with every thermostat I've ever installed.
Reply #5March 16, 2009, 11:54:21 am
  • 3468
    • McScrubbins Body Wash
Vented Thermostats
« Reply #5 on: March 16, 2009, 11:54:21 am »
Quote from: "red64chevelle"
Very interesting.... I'm getting tired of my metronome gauge.
Reply #6March 16, 2009, 06:05:26 pm
Rabbit TD
  • 840
Vented Thermostats
« Reply #6 on: March 16, 2009, 06:05:26 pm »
The reason I asked is that I've had 2 of them now since I've been folling with the diesels and both were 180's {vented}.  I had one in the other engine to replace a 195 and I ended up putting the 195 back in because the 180 actualy got hotter after a while.  Then I got a 180 from Parts Place and that one has worked perfect for 3 years crossing the mountains and all in the Summer.  I got a new one with this rebuild kit but it was a 195 and since I wanted a 180 again instead of taking the one from the other engine I got one from Autozone which was vented and it also showed higher than it should on my Autometer gauge and since it was spitting out the cap I put the 180 from the old engine today and the temps stay right around 180 as they should and I can fill the reservoir to the right place and it stays there and holds pressure without blowing out.  Vented Autozone one would spray with just an inch of coolant  the tank.
   One of the 180's that was vented  was a Stant and I don't know what the first one was though anymore, possibly a Stant also.  The 180 from Parts Place is a non-vented 180 and is the only thermostat for these engines that ever worked right for me.  Honestly I don't remember the name of it but I know it was German.  I thought I had a head gasket leaking and it was that damn thermostat :roll:
