Fitting 2.5 Turbo, Pump and injectors to a 1.6 SB?
Topic: Fitting 2.5 Turbo, Pump and injectors to a 1.6 SB? (Read 2305 times)
August 19, 2005, 07:35:26 pm
GTD.
August 19, 2005, 07:35:26 pm »
I read somewhere that the turbo off a 2.5TD (Transporter Van) can be fitted to a 1.6 SB engine, will this work and will it smoke a lot, mt current engine only smokes on startup and has done less tha 65k.
Cheers
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
August 20, 2005, 11:07:55 am
vwmike
Authorized Vendor
August 20, 2005, 11:07:55 am »
I can't really directly comment on the turbo as they didn't even sell those engines in this country, but I would think that it'd be bigger than the stock one. I could be wrong though. The Volvo straight 6 diesel (VW engine) had the same size turbo as our 1.6's. Assuming it is bigger than your stock one then I would make sure that you've reached the limits of the stock turbo before getting into switching turbos. The pump will not work though as it is for a 5cyl.
