Author Topic: Prosport EGT Gauge and Dakota Tach Box  (Read 4238 times)
March 14, 2009, 08:49:58 am
flash319
  • 163
« on: March 14, 2009, 08:49:58 am »
I have a Prosport EGT gauge for sale.  Used about 3 months and works perfect.  I got it off Ebay (search and you will find the same one Amber/White lighting) and payed $150 US for it.  Would like to get $120 CAD for it.
I also have this Dakota Tach converter box.  It will take a alternator tach signal and make it work with a normal tach.  $50 CAD
Reply #1March 19, 2009, 09:14:51 am
« Reply #1 on: March 19, 2009, 09:14:51 am »
how much USD$ for the tach box? and i dont mean to piss in your cheerios or anything, but im pretty sure prothe sells that same gauge for like.. 44 bucks brand new. looks the same at least. i may be wrong.
Reply #2March 19, 2009, 09:58:27 am
flash319
  • 163
« Reply #2 on: March 19, 2009, 09:58:27 am »
I will send you the box for $45US.  I paid $150 ++ for the EGT guage and probe off Ebay.  If you can get a EGT guage and probe for $44 more power to ya but I very highly doubt it.
Reply #3March 19, 2009, 10:39:30 am
« Reply #3 on: March 19, 2009, 10:39:30 am »
http://www.dieselvw.com/EGTGauge.htm
44 dollar egt gauge  :wink:
and im pretty sure i want the tach box. is it brnad new? or has it been run? it would be sweet if its already calibrated.
Reply #4March 19, 2009, 10:49:41 am
flash319
  • 163
« Reply #4 on: March 19, 2009, 10:49:41 am »
It was run for about 2-3 months.  It was on a 1.9.
Reply #5March 19, 2009, 10:53:44 am
« Reply #5 on: March 19, 2009, 10:53:44 am »
did the 1.9 have a serp setup on it? or did it have the old style V belts? cause if your pulleys are the same size as mine, or i can find the pulleys you calibrated it with, ill buy it for sure. i just have no way of calibrating it once i get it.
Reply #6March 19, 2009, 12:33:37 pm
« Reply #6 on: March 19, 2009, 12:33:37 pm »
Quote from: "Rabbit on Roids"
you can calibrate using the gearbox ratio's and your spedometer or gps.  its not as accurate as using a digital rpm gauge though.
Reply #7March 19, 2009, 02:07:14 pm
« Reply #7 on: March 19, 2009, 02:07:14 pm »
Quote from: "jtanguay"
i did mine by ratios, you can get it pretty much spot on this way.
