Author Topic: A2 injection pump-- ECO vs N/A  (Read 4946 times)
August 19, 2005, 03:29:38 pm
Bludodger
  • 48
« on: August 19, 2005, 03:29:38 pm »
I have a '91 ecodiesel that I would like to swap the pump out for a true turbo inj. pump. I have a replacement pump w/ a LDA. I know that the A2 N/A diesel pumps look like the turbo pumps because they have an altitude adjustment LDA on top. Before removing the existing pump, I would like to confirm that the pump I want to swap ino the Eco is in fact a true turbo pump w/ boost enrichment and not a N/A pump with a Altitude adjustment LDA. Is there a quick way to tell? If need be, I have the part #s. I looked in the archives and didn't find this exact question or answer...
Thanks
Andrew
Reply #1August 19, 2005, 05:47:19 pm
vwmike
  • 1158
« Reply #1 on: August 19, 2005, 05:47:19 pm »
Can you post the part numbers?
Reply #2August 19, 2005, 06:51:53 pm
Bludodger
  • 48
« Reply #2 on: August 19, 2005, 06:51:53 pm »
#'s on the pump body
068 130-110N
254-BS-4010
0 460 494 200
#'s on the LDA
1 465 530 724
2.3
Reply #3August 19, 2005, 07:14:40 pm
vwmike
  • 1158
« Reply #3 on: August 19, 2005, 07:14:40 pm »
Quote from: "Bludodger"
068 130-110N
254-BS-4010
0 460 494 200
#'s on the LDA
1 465 530 724
2.3
I'm sorry to say that is an 89-92 NA pump for the ME engine. 068 130 081 FX is the TD pump (MF engine code).
Reply #4August 19, 2005, 08:22:02 pm
Bludodger
  • 48
« Reply #4 on: August 19, 2005, 08:22:02 pm »
Thanks for the help
Anyway to make it a turbo pump? What exactly is the difference?
Anyone have an extra turbo pump?
Reply #5August 20, 2005, 12:25:51 am
Maarten
  • 339
« Reply #5 on: August 20, 2005, 12:25:51 am »
A true turbo pump has a line from the inlate manifold onto the LDA, that pressure pushes the LDA down.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #6August 22, 2005, 12:54:12 pm
janb
  • 167
Re: A2 injection pump-- ECO vs N/A
« Reply #6 on: August 22, 2005, 12:54:12 pm »
IIRC... the altitude compensation (no fuel enrichment) has a vac line that runs over to fuel filter.
With  Boost enrichment, the line runs to intake manifold
janb
The Stealth Rabbit
VW-d's are forever
Reply #7August 30, 2005, 12:03:20 pm
entuzijast
  • 73
    • http://www.geof.hr/~imalovic
« Reply #7 on: August 30, 2005, 12:03:20 pm »
Can you please tell me engine code for this pump
068 130 109 S
0 460 494 138
Excuse me on my bad English
