Author Topic: new user asking for help :)  (Read 6631 times)
June 14, 2004, 06:33:51 pm
Golden_graham
  • 2
« on: June 14, 2004, 06:33:51 pm »
Hi there,
this is my first topic here, and i have a question for you...
could you give the compression ratios and "bore&stroke"sizes of some tdi models?
sorry about my english
GG
Reply #1June 15, 2004, 09:16:50 am
type53b_gtd
  • 118
    • http://scirocco.cs.uoguelph.ca/gtd/
« Reply #1 on: June 15, 2004, 09:16:50 am »
The 1.9 TDIs are 79,5mm bore  X 95,5mm stroke (as are the 1.9 IDIs) Compression ratio on the 1.9 distributor pump TDIs is 19,5:1, and on the PD it is 19:1
The V10 TDI is 81,0mm bore X 95,5 mm stroke, and I believe the CR is 18:1, but I'm not sure.
the 2L TDI is 81,0mm bore X 95,5mm stroke, with 18.5:1 compression ratio .
The 1.4 TDI (3 cylinder) is also 79,5x95,5 with a 19,5:1 CR.
You should also be able to glean specs on the current models from www.volkswagen.de - correct me if any of the above is wrong... :)
HTH,
Drew
PS - don't apologize for your english - its obviously quite acceptable! :)
Reply #2June 16, 2004, 05:52:51 am
Golden_graham
  • 2
« Reply #2 on: June 16, 2004, 05:52:51 am »
type53b> thanks for the answer...
I was looking for the "bore&stroke" of the old 2.5tdi, 5cyl... that came into VW transporter (europe, i think) or caravelle... but i can't find them :(
about my english, you don't imagine how many times i write... read... erase.... rewrite a post, LOL
but that's ok... thank god there is a universal language that we all can understand... and thank god my english teacher (many years ago) was a sexy lady... i never missed a class.  :D
Reply #3June 16, 2004, 06:25:42 am
type53b_gtd
  • 118
« Reply #3 on: June 16, 2004, 06:25:42 am »
Quote from: "Golden_graham"
Oh, Ok.  Forgot about the grandmama of all TDI's.
The 2.5L 5 Cylinder TDI had an 81mm bore and 95.5mm stroke for 2.46 displacement.
There's a 2.5L V6 TDI as well, but I can't find any info about it.
Heh heh - I hear you there - obviously it paid off... :)
Drew
