Author Topic: Really dumb question  (Read 2898 times)
March 06, 2009, 10:23:30 pm
RustyCaddy
  • 395
« on: March 06, 2009, 10:23:30 pm »
My gigantic ego has held me back from asking this stupid question but here goes.
Am putting a 1.6 NA back together with fresh bore, pistons and Mahle rings.
Having never done this much to any engine and being clueless I see the rings are marked with a "c" on one side...I think this means top as in towards this side towards the crown and not the crankshaft???
any help is appreciated...
Reply #1March 06, 2009, 10:44:30 pm
maxfax
  • 2126
« Reply #1 on: March 06, 2009, 10:44:30 pm »
If you got any literature with the pistons check that..   If that says nothing then yes C goes towards teh crown...
It's not a dumb question unless you ask it after you screw up..  :D  Using that logic, yes I have asked dumb questions..
Reply #2March 06, 2009, 11:16:38 pm
Rabbit TD
  • 840
« Reply #2 on: March 06, 2009, 11:16:38 pm »
I don't think I've ever seen a ring on anything that had a mark on one side only that didn't face the top of the piston.  But some have no marks that are different but have a diagram to show which way to put them.
Reply #3March 07, 2009, 12:01:46 am
maxfax
  • 2126
« Reply #3 on: March 07, 2009, 12:01:46 am »
I was putting rings in a 1927 Pontiac once..   There was a "A" on one side, and a "B" on the other...  Apparently they fit several dozen applications just by flipping them over..   Woulda been nice if they had send some instruction with them...
Reply #4March 07, 2009, 10:32:43 am
RustyCaddy
  • 395
« Reply #4 on: March 07, 2009, 10:32:43 am »
Thanks guys!
I looked up the portugese word for "top" (they are Brazilian rings) and it listed a coupel of words that started with "c".
Maybe that was what is was about.
"a" on one side "b" on the other; that can't be funny when it is happening
Reply #5March 07, 2009, 10:53:00 am
« Reply #5 on: March 07, 2009, 10:53:00 am »
No dumb questions here (slightly tiring ones sometimes if they're already in the FAQ, but that's a different story :wink:).
A couple of other cross-triangulation points:
- do either of the top two rings have bevels ?  If so, you might be able to match them with standard Goetz ring instructions... I've got a kit somewhere I can scan if that helps
- in general, if there's labeling on only one side of a mechanical part it's installed "label side up"
Reply #6March 07, 2009, 11:18:02 am
maxfax
  • 2126
« Reply #6 on: March 07, 2009, 11:18:02 am »
Quote from: "RustyCaddy"
Thanks guys!
Now that's  thinkin right there..  Would make alot of sense
No it isn;t...   Especially when it's someone else's money you could be screwing up...
