Author Topic: pump build question  (Read 2106 times)
March 02, 2009, 06:13:23 am
dts67
  • 68
pump build question
« on: March 02, 2009, 06:13:23 am »
Building an mtdi pump and Ive got an 11mm donor pump, the problem is its off a uk rover 420 and turns counter-clockwise, I understand the camplates different but can I use the 11mm head/plunger?
Reply #1March 02, 2009, 06:20:10 am
gigaz2
  • 626
pump build question
« Reply #1 on: March 02, 2009, 06:20:10 am »
unfortunately no, the feed ports  for the plunger are on the other side  :(
Reply #2March 02, 2009, 06:55:12 pm
Hey
  • 339
pump build question
« Reply #2 on: March 02, 2009, 06:55:12 pm »
what if you turn the plunger (in fact the camplate) 180°... will it be aligned?
Reply #3March 03, 2009, 03:09:26 pm
Hey
  • 339
pump build question
« Reply #3 on: March 03, 2009, 03:09:26 pm »
Libbybapa ...did you tried inverting the camplate?
Reply #4March 05, 2009, 02:47:58 pm
dts67
  • 68
pump build question
« Reply #4 on: March 05, 2009, 02:47:58 pm »
Thanks, I just got another 11mm donor pump from a uk transit van, the transit pump and the rover pump are both m-tdi pumps from the factory, am I right in saying using the governor and principle levers from either of  these pumps will save me modifying my own idi levers? Its all on and starting/reving anyway but havent had it on the road yet.
Just realised this might be in the wrong section :oops:  I drive a peugeot 1.9 d-turbo, didnt notice the other makes section :roll:
