Author Topic: FS: STANADYNE DIESEL TIMING LIGHT Model TT1000 (like new)  (Read 7340 times)
March 01, 2009, 09:27:08 pm
AudiVWguy
« on: March 01, 2009, 09:27:08 pm »
I have for sale a Stanadyne Diesel Timing Light Model TT1000. It is in like new condition.
General Info:
   The TIME TRACK meter features a revolutionary new concept in diesel engine timing devices. It utilizes the very latest in digital electronics and provides versatility for use with most pump-line-nozzel diesel engines. It operates on the electrical pulse provided by a piezoelectric device that can be either permanently mounted inline or clamped onto the injection tubing itself.
   The advantage in using the TIME TRAC meter is that the engine can be checked dynamically and accurately while running as opposed to the time-consuming methods using dial indicators, locking pins, or flow and air timing.
   The TIME TRAC meter can be used to check timing on most diesel vehicles equipment with an in-line or rotary pump, nozzles, and high pressure fuel lines.
   This includes cars, light duty trucks, construction, agricultural, and marine equipment.
This comes with the main control box, which runs on a 9v battery (included) the timing light,  the piezoelectric sensor, and the instructions.
First $325.00 takes it.
Thanks for looking,
--Jeff
[/b]
Reply #1March 02, 2009, 07:27:00 am
subsonic
  • 1836
« Reply #1 on: March 02, 2009, 07:27:00 am »
How did it work for you?  Time saver?
Reply #2March 02, 2009, 11:10:27 pm
AudiVWguy
« Reply #2 on: March 02, 2009, 11:10:27 pm »
It works great and has an incredible number of features. Where my intercooler hoses inter and exit are right above the timing hole. In my case its extremely difficult to see the timing hole. I ended up with two of these so this is an extra.
Reply #3March 03, 2009, 12:20:04 pm
subsonic
  • 1836
« Reply #3 on: March 03, 2009, 12:20:04 pm »
Don't think I can afford it, but thought I will ask, So this will work on IDI, TDI, and m-tdi.  Would it work on the new CR?
