Author Topic: boost gauge install HELP!!!!!!!!  (Read 4780 times)
February 26, 2009, 07:28:56 pm
L1V3N 1T
  • 13
« on: February 26, 2009, 07:28:56 pm »
hey new to this TD stuff where can i tee in for the boost gauge hose. cant find any lines any where around the engine.
Reply #1February 26, 2009, 08:16:44 pm
Kantdrivefast
  • 196
« Reply #1 on: February 26, 2009, 08:16:44 pm »
I tee-ed mine into the line that runs from the turbo to the LDA.
Reply #2February 27, 2009, 05:55:22 am
nogama3
  • 162
« Reply #2 on: February 27, 2009, 05:55:22 am »
what car do you have? engine? a few bits of info would help us to help you.
Reply #3February 27, 2009, 09:17:58 am
L1V3N 1T
  • 13
« Reply #3 on: February 27, 2009, 09:17:58 am »
my bad its a 1990 jetta 1.6TD. that line that you are talking about kantdrivefast that is the steel one right.
Reply #4February 27, 2009, 11:15:50 am
TurboJ
  • 661
« Reply #4 on: February 27, 2009, 11:15:50 am »
No.
You want to use the line that connects to the fuel pump - the mushroom shaped thing on top of that (called LDA). That line should be rubber!
The feed for that should come from the inlet manifold 'elbow' in most cases.
Using that line to fit the 'T' will tell you the pressure that's entering the engine, disrecarding all the pressure drop associated with the possible intercooler, boost pipes etc.
Jetta II 1.6 TD 'Project 200'
Reply #5February 28, 2009, 09:53:48 am
kaneb
  • 164
    • www.dasdubbers.org
« Reply #5 on: February 28, 2009, 09:53:48 am »
Heres a pic from a local guy.
This should explain all.
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #6February 28, 2009, 02:56:18 pm
Jettagli16v
  • 344
« Reply #6 on: February 28, 2009, 02:56:18 pm »
Depending on where he lives (Update your profile, dude!)
a 1990 TD Jetta in the US is just an Eco,
therefore, no LDA...
I dont know where to tap that but any vacuum line connected to the intake manifold should do fine.
-Brad
Reply #7February 28, 2009, 03:38:10 pm
kaneb
  • 164
« Reply #7 on: February 28, 2009, 03:38:10 pm »
I don't have an LDa with my turbo NA.  I run my boost gauge right off the intake manifold with some 1/4" synflex tubing.
Works like a charm.
Kane
www.dasdubbers.org
Reply #8February 28, 2009, 06:46:36 pm
L1V3N 1T
  • 13
« Reply #8 on: February 28, 2009, 06:46:36 pm »
i have a 1990 jetta wolfsburg and i live in canada
i think i do have the LDA i remember that hose going to it
another question the egt temp what should it range between to be safe??
Reply #9March 01, 2009, 07:29:18 am
kaneb
  • 164
« Reply #9 on: March 01, 2009, 07:29:18 am »
If your egt probe is mounted into the exhaust manifold before the turbo max. i would take it up to is 1400.
Kane
www.dasdubbers.org
