Author Topic: Parts place head?  (Read 10380 times)
Reply #30March 08, 2009, 04:13:08 pm
Parts place head?
« Reply #30 on: March 08, 2009, 04:13:08 pm »
http://stores.ebay.com/J-and-C-Cylinder-Head-Exchange
I had these guys do my first head for vw diesel. It ran good for as long as I had it. I don't think they replaced all of the valves, but it was for an n/a and if you request it they said they would do anything for additional cost. They also found my friend another head casting as his was not rebuildable. Maybe you can call them and find something. The one time they had a mechanical head on the shelf, but I needed a hydro. Don't worry about the ebay part and the store site that doesn't even list a vw head...I found them off line and they have just about every cylinder head on the planet.
Reply #31March 08, 2009, 04:38:22 pm
somepunk22
  • 79
Parts place head?
« Reply #31 on: March 08, 2009, 04:38:22 pm »
Message sent. Thanks for the tip.
Reply #32March 08, 2009, 07:50:29 pm
AudiVWguy
Parts place head?
« Reply #32 on: March 08, 2009, 07:50:29 pm »
Here's some more info on places I've turned to again and again.
TOPLINE
Corporate Office
8150-8200 South Hoyne Avenue, Chicago, IL 60620 USA
PH: 800-44101400      Fax:773-487-1403
http://toplineauto.com
CANADA
7650 Kimbel Street. Mississauga, Ontario L5S1L2
800-435-3986    905-677-0996     Fax:800-706-4456
MIDWEST FUEL INJECTION
1100 Hosler Drive
Bolingbrook, IL 60490
815-866-9900
www.MWFI.com
The website has other locations.
They rebuild the pumps for The Parts Place
They have really good prices for injectors
NORTHSIDE IMPORTS, INC.
3650 West Pratt     Lincolnwood IL 60712           800-247-2491
3605 Kennedy Road      So. Plainfield NJ 07080     888-472-0455
25-06 BQE West     Woodside, NY 11377      888-472-0455
5060 Convoy Street     San Diego, CA 92111     866-671-9249
www.northsideimports.com
These people have great prices on OEM parts
FORNPARTS
501 Ogden Ave     Downers Grove, IL 60515     630-963-4621
Another good source for OEM parts.
Reply #33March 10, 2009, 10:28:26 am
somepunk22
  • 79
Parts place head?
« Reply #33 on: March 10, 2009, 10:28:26 am »
Emails sent all around. No luck so far. Will it just be easier to buy a new hydro head for my mech block then to find a decent mech head? Seems to be quite a few people going that route. $600 shipped from one of our vendors...
http://vwdiesel.net/phpBB/viewtopic.php?t=11016&postdays=0&postorder=asc&start=60&sid=119e15e900673b5530913afc746b873a
Reply #34March 11, 2009, 05:37:44 pm
Parts place head?
« Reply #34 on: March 11, 2009, 05:37:44 pm »
1100 Hosler Drive
815-866-9900
www.MWFI.com
I think these guys use junky IP bushings. I had 8-9 months on one of their pumps and the bushings got sloppy. They have a 1 year warranty but they still charged me $95 to put new bushings in and forgot to send it back for 2 weeks after it was done. Now the bushings are bad again less than a year and a half later.
The belt hasn't been over tightened because the IM bearings are still good.
I'm trying to try not to bash 'em, I'm glad they still do vw IPs and injectors I just feel like I got took is all.
Reply #35March 11, 2009, 09:45:44 pm
Rabbit TD
  • 840
Parts place head?
« Reply #35 on: March 11, 2009, 09:45:44 pm »
Quote from: "rabbitman"
1100 Hosler Drive
815-866-9900
www.MWFI.com
I don't know how tight you are actualy tightening the belt but if you can't twist it in the middle of it's longest span from the pump to the head 180 degrees in the middle of the span its too tight. That's just a common adjustment on all timing belts if it has a manual adjustment.  If it sings similar to a turbo sound after you adjust it it's really way too tight.
Reply #36March 14, 2009, 11:19:20 am
Parts place head?
« Reply #36 on: March 14, 2009, 11:19:20 am »
The first time the IP bushings wore out  the owner of the vw shop I was working at helped me tension it so I know it wasn't overtightened.
Actually the bentley says 45 degrees, if you were to twist it 180 degrees the belt would be way too loose and would slip or else you'd wreck the belt.
I had it do that with my first pump. I went on a 5,000 mile road trip and 1,000 miles into it the belt started singin', I finished that trip still runnin' fine. Later I went on a 3,200 mile road trip to wisconsin and when I got there I had a terrible fuel leak out the back of the pump. That had nothing to do with overtightening the belt, I think it was caused by the ULSD.
That was when I bought a new IP and installed it as I said above.
Reply #37January 31, 2012, 09:17:53 am
DarkwingDork
  • 24
    • Mk1Ultra.com
Re: Parts place head?
« Reply #37 on: January 31, 2012, 09:17:53 am »
1100 Hosler Drive
815-866-9900
www.MWFI.com
I know this thread is pretty much dead, but I wanted to give MWFI a little praise. I bought a set of injectors for my old 7.3L IDI from them a couple years ago. They had the best price I could find, all 8 pop-tested within spec, and they worked flawlessly until I sold the truck a couple years later.
As for PartsPlace Inc. I've spent a good few hundred bucks there in the last few years and have always had good luck with them. I have a set of their HD springs on the Rabbit...LOVE them! Tighter handling, no squatting under heavy load, perform just like they did when they were new after two years of driving the living HELL out of them (and I'm rough on suspension parts). *twisted*
Yes, their prices are steep, no arguments there. I need to find another source for rebuild parts...I has a feeling I can get quality for less.  :-\
1984 Rabbit Wolfsburg 1.6/5-speed
My Mk1 FAQ/DIY site:
http://mk1ultra.com
My build thread:
vwdiesel.net/forum/index.php?topic=30776.0
