Author Topic: Which oil return line for T3 on 1.9?  (Read 4842 times)
February 24, 2009, 11:22:03 pm
rabbid79
  • 684
« on: February 24, 2009, 11:22:03 pm »
Hi, I'm providing help over the phone for a friend of a friend installing a 1.9 into his Caddy.  It should be a pretty nice ride once complete.  He even purchased a Giles pump for it.  Anyway, he has decided to go with a T3, but apparantly it has a massive oil return flange compared to the new oil return line he has.  I assume that the line he has was intended for a K03 with a smaller flange?  Is there a specific oil return line he could order from VW that will properly adapt to the T3 and drain into the back of the block?  If such a part exists, and if anyone has a part number I would be appreciate your input.  Thanks.
'15 WRX
Reply #1February 25, 2009, 07:22:56 am
stewardc
« Reply #1 on: February 25, 2009, 07:22:56 am »
When I put the T3 on my AAZ, I took both end fittings and a measurement to a local hydraulic hose shop. They made a very nice stainless braided hose and supplied the fittings to replace the banjo fitting with a JIC flare.
Reply #2February 26, 2009, 05:08:05 am
dieselherb1
  • 354
« Reply #2 on: February 26, 2009, 05:08:05 am »
I am installing a T3 on a N/A engine. I got hydraulic hose(got mine from Surplus center, but Harborfreight and tractor supply sell them) and fittings and drilled a hole in the oil pan, welded a nut inside the pan. Threaded the flange to the turbo. Hose and fittings $15. If you can find a shop to make you a hydraulic line you could go stock looking but might be expensive.
