Author Topic: MPI IMMOBILIZERS  (Read 11744 times)
February 22, 2009, 04:22:31 pm
dieselsmoke
MPI IMMOBILIZERS
« on: February 22, 2009, 04:22:31 pm »
Has anyone here on the forums that live in manitoba had to put one of those crappy MPI IMMOBILIZERS into there diesel vw yet? They have them issued for the 90 - 94 jetta and golfs and I believe the passats as well. Has anyone disabled them before? I have heard of at least a few dozen people I know that have had nightmares after these POS things were installed. I would just like to "cut a wire" to disable it so it dosen't effect my car and then re-enable it once I want to sell the car. I know on the 93-94 the electrical is alot more touchy and complex then the 90-92. If anyone has tips on this please let me know.
Reply #1February 22, 2009, 04:30:12 pm
hamradio
  • 282
MPI IMMOBILIZERS
« Reply #1 on: February 22, 2009, 04:30:12 pm »
What exactly is it?
Reply #2February 22, 2009, 06:30:07 pm
MPI IMMOBILIZERS
« Reply #2 on: February 22, 2009, 06:30:07 pm »
i think the immobilize he's talking about is for insurance purposes only...  to reduce car thefts (so they insurance companies don't have to pay out as much... wow maybe they could pass on the savings to the customers? nah... what was i thinking?  :roll:)
whats so bad about the MPI immobilizer anyway?  does it have a special key?  if you really want, you could install your own circuitry. i've been contempating building a push button ignition system.  one circuit board could be used to trigger the accessories to toggle "ON" and another circuit to toggle the starter as a momentay switch, but then have it toggled off so that you don't re-engage the starter when you press it to turn off the motor.  the parts to get that going would probably cost about $50. to make it even more complex, you could wire in a signal from the alternator to disengage the starter much like a remote starter would do.
other than that, you could try an on/off switch for the accessories, and a momentary switch for the starter.
Reply #3February 23, 2009, 07:09:16 am
dieselsmoke
MPI IMMOBILIZERS
« Reply #3 on: February 23, 2009, 07:09:16 am »
Yeah, it is for insurance purposes only. MPI makes you put them in if you have a most at risk vehicle or you can't register your car. Funny though that they only put 90-94 vws since the 86-92 and 93-96 have pretty much the same electrical.
The imobilizers that they use are passive ones that basically just use the key fob that has to be close to the steering column when you go to start the car or else it won't work.
The problem I have with them is that these things are screwing up the electrical systems of tons of vehicles and causing alot of people to get stranded because their vehicle will not start because of these. I know first hand of at least a couple dozen people this has happened to and I don't want this to happen to me with a kid in the car and being stuck because this POS won't let you start your car. For the Diesels I have heard of it screwing up the electrical to the point where it won't let your glow plugs work and if that happens in winter you can bet on not starting your car. Then you have to pay to get things fixed after these pieces of crap screw your car up. With us driving German cars you can sure as heck bet on having some noob who  has never touched the electrical of a german car go in and install this and then screw up the electrical in your car.
MPI says that it must be one of the following models and must be done by an approved installer (no DIY installs):
PFK Autowatch 329 Ti Immobilizer
MasterGard M6000 Immobilizer
MasterGard TK Immobilizer
Powerlock-Canada Immobilizer
So, since they are forcing you to get this done I have no choice but I will be disabling it or ripping it out of my car after they are done making a mess of my electrical.
Oh I forgot to mention that if you have any other "existing" electrical problems that the shop "has" to fix before they can do the install then you have to pay for that as well which is a joke since if they want me to put this crap in MPI should pay for it. Man I hate MPI.....
Reply #4February 23, 2009, 07:30:50 am
arb
MPI IMMOBILIZERS
« Reply #4 on: February 23, 2009, 07:30:50 am »
What is MPI ? Is it a brand of insurance ? Can't you switch companies so you don't have to go through this?
Reply #5February 23, 2009, 07:36:50 am
drrtybyl
  • 146
MPI IMMOBILIZERS
« Reply #5 on: February 23, 2009, 07:36:50 am »
BMW has a similar immobilizer that started with the E36 platform.  System includes a rotating passkey that must match the code transmitted by the chip in the key, which otherwise prevents ignition.  Great preventive measure for auto theft, fairly bad for non-car thieves.  Lots and lots of stories about stranded cars with malfunctioning EWS.  OBDII engine swaps typically involve towing the car to the dealer to have EWS realigned.
'79 Rabbit Diesel L
'94 Chevy 2500 6.5TD
'96 BMW 318ti
Reply #6February 23, 2009, 07:56:14 am
dieselsmoke
MPI IMMOBILIZERS
« Reply #6 on: February 23, 2009, 07:56:14 am »
MPI is Manitoba Public insurance. It is a government Monopoly. You can only get your insurance through them in Manitoba. Believe me if I could go private or with someone else I would.
Reply #7February 23, 2009, 08:03:00 am
MPI IMMOBILIZERS
« Reply #7 on: February 23, 2009, 08:03:00 am »
Quote from: "dieselsmoke"
That is the biggest SHAM i have ever heard of  :shock: !
Thats actually sickening.. Stupid government.
Reply #8February 23, 2009, 08:08:46 am
dieselsmoke
MPI IMMOBILIZERS
« Reply #8 on: February 23, 2009, 08:08:46 am »
Welcome to communist, Russia.
Check out the link below, it will make you sick.
http://blog.canoe.ca/raisinghell/2008/06/18/mpi_shares_private_info
Reply #9February 23, 2009, 08:19:44 am
arb
MPI IMMOBILIZERS
« Reply #9 on: February 23, 2009, 08:19:44 am »
A while back, we had a Tea Party in Boston for smaller reasons !!  LOL
If you move down to Wisconsin, they don't require insurance on your vehicle at all !!! If you cause a personal injury accident, they will force to you place a $5,000 cash bond with the state until the injury is healed.
Reply #10February 23, 2009, 08:28:43 am
drrtybyl
  • 146
MPI IMMOBILIZERS
« Reply #10 on: February 23, 2009, 08:28:43 am »
^^^awesome
What happens if you can't front the cash?  Do they suspend your license?
That sucks..
Kind of like being legally required to pay for auto insurance in general  :wink:
'79 Rabbit Diesel L
'96 BMW 318ti
Reply #11February 23, 2009, 08:28:57 am
arb
MPI IMMOBILIZERS
« Reply #11 on: February 23, 2009, 08:28:57 am »
We are not too far behind in some areas - The world's largest police air force gets their planes by confiscating them from "suspects". If you are flying into Detroit City airport, and our air traffic control takes you a little south across the river into Canada's airspace, our Customs & Boarder Patrol Nazi can take your plane for themselves...
http://www.cbp.gov/xp/cgov/border_security/air_marine/
Reply #12February 23, 2009, 08:31:48 am
MPI IMMOBILIZERS
« Reply #12 on: February 23, 2009, 08:31:48 am »
MPI is turning into an NDP cash cow. It's time to bring that fat cow to slaughter.   :lol:
Reply #13February 23, 2009, 08:50:16 am
dieselsmoke
MPI IMMOBILIZERS
« Reply #13 on: February 23, 2009, 08:50:16 am »
I have been screwed by MPI a few times already and can't stand them. If anyone gets one of those imobilizers installed and figures out how to disable them so they don't screw your electrical please let me know. I will be gettng mine done and will figure out how to get rid of it myself if no one here figures out how to do it.
Reply #14February 23, 2009, 08:55:02 am
arb
MPI IMMOBILIZERS
« Reply #14 on: February 23, 2009, 08:55:02 am »
How much do you have to pay for the device?
