Author Topic: GL4-GL5  (Read 1900 times)
February 22, 2009, 12:15:59 am
Rabbit TD
  • 840
GL4-GL5
« on: February 22, 2009, 12:15:59 am »
I'm reading again about the gear oil for the o20 transmissions requiring the GL4 only oil and again I got the Amsoil MTG 75-90 GL4 as it worked fine in the last one I rebuilt, better have damn good seals in it though especialy the input shaft one and the axel flange seals.  My question is that all the information I read everywhere on all forums say the GL5 is bad for all things brass especially the synchronizers rings.  I've never seen a synchronizer anywhere that didn't have a brass ring so what is GL5 supposed to be used for anyway.  Are there synchronizers that aren't made with brass rings and what are they actually made of  :?:
Reply #1February 22, 2009, 06:32:36 am
hamradio
  • 282
GL4-GL5
« Reply #1 on: February 22, 2009, 06:32:36 am »
The vw trans has brass syncros.
Why are you super concerned about using gl5 in your trans if you're already using gl4 without issue?
