Author Topic: air in fuel, car not running  (Read 1981 times)
February 20, 2009, 06:52:41 pm
kaneb
  • 164
    • www.dasdubbers.org
« on: February 20, 2009, 06:52:41 pm »
Hello,
I recently found my car was sucking air in with fuel causing it to not run properly, stalling and such.  It did it only on hard pulls then got worse and worse.  I found out my fuel filter was loose, Now after removing fuel filter and filter not having barely any fuel in it i filled it with fuel, cracked the lines at the injectors and started cranking.  Is there an easy way to get the air out of the lines so i can get this thing running again? Wish it had a primer.
Any Help is appreciated, Thanks!
Kane
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #1February 20, 2009, 07:52:00 pm
Rabbit TD
  • 840
« Reply #1 on: February 20, 2009, 07:52:00 pm »
The easiest way to prime one of these diesels is to fill the fuel filter like you did, then remove the banjo bolt on the pump for the return line and fill the pump with fuel.  Crack the lines to all the injectors just a little and crank the engine till fuel leaks out of each line and then tighten them up and start the engine.  It will stumble for a little but bleed itself in short time, assuming there are no leaks in the system.  Make sure the wire to the fuel shutoff solenoid on the pump is connected while you are cranking with the injector lines cracked, lots of people pull the wire so the car won't start doing this but no fuel will go to the injectors, the engine wont start anyway because there won't be enough pressure to pop the injector if it's loose enough to watch for the fuel to dribble from them.  The air in the system anywhere will bleed itself as long as there are no places to enter in the first place.
Reply #2February 21, 2009, 05:17:09 am
« Reply #2 on: February 21, 2009, 05:17:09 am »
What year is your car?
If possible, to save your starter have someone pull start you
Reply #3February 21, 2009, 06:58:30 am
kaneb
  • 164
« Reply #3 on: February 21, 2009, 06:58:30 am »
car is an 83 rabbit, So prettyy much pull sart to get the air out and fuel in ya?
Kane
www.dasdubbers.org
Reply #4February 21, 2009, 08:37:15 am
kaneb
  • 164
« Reply #4 on: February 21, 2009, 08:37:15 am »
got it running this morning. took off the return line cracked my injectors. got my little shop vac and put on top of the return of the pump and cranked. it drew all the air out. put it all back together and it fired about 5 cranks after.
Thanks for the help guys!
www.dasdubbers.org
