Author Topic: FS Feeler: 1z/AHU rebuilt shortblock, head, CTN Trans, MORE  (Read 4736 times)
February 18, 2009, 05:40:57 pm
RabbitGTDguy
  • 1274
« on: February 18, 2009, 05:40:57 pm »
Well, since the b3 is now gone, I'm giving some thought to looking at future projects, etc. and considering selling the motor that I had been building for the b3 wagon that I had here.  I don't have pictures right now but will take some and have them up tomorrow on here.
Up for grabs is the following:
-Completely rebuilt and overbored (1st oversize) 1z/AHU shortblock
-Complete 1z/AHU head (not rebuilt at the moment)
-CTN TDI 02j 5 speed manual transmission (in great shape, 120k)
-All accessories for this motor that I have compiled as well as other "new" parts to finish the build.
Why am I not "finishing" it all? Well, I'd never get the money and time invested in the complete longblock and/or complete motor build and since I don't really have a car to put the motor in at the moment (I've got new TDI plans brewing for other future projects) and already have the mTDI in my MK1, I thought I'd do what I could with what I have here at the moment and just sell those other bits.  I have had some interested parties in the shortblock itself but honestly...money talks.
So...the details.
1z/AHU Shortblock (Oil pan to top of block complete, no accessories) to include:
-Completely stripped, tanked, acid dipped block it was then sandblasted as well.  Engine primer enamel (2 coats) and then 3 coats of Ford Blue engine enamel
-Block was professionally overbored to accomodate the 1st oversize
-Crank polished
-All rods checked and resized properly
-All tolerances measured in spec w/ exc. to overbore.
-Installed ALL OE parts to include:
+Nural/Goetze ALH style pistons in the first oversize (+.05)
+Main Bearings with non-integrated thrust bearing (6pc)
+Rod bearings
+All seals to include int. shaft, front and rear mains, mains to block, etc
+New windage tray for oil pan
+New oil pan
+New crankshaft sprocket bolt (of course)
Shortblock is complete right now (no accessories) and ready to go.
Additionally, I have a complete 1z/AHU head that is in good shape, no bent valves.  Was for the top end of this project. Have injectors (good for mTDI, 3rd injector needle lift sensor cable was cut by PO).
For the head, I also have finished parts for the build such as:
-A set of raceware head studs
-blasted/primed and painted (Ford Blue) valve cover
-blasted/primed and painted (Ford Blue) injector hold downs
-blasted/primed and painted (Ford Blue) cam sprocket, int. sprocket, IP sprocket maybe too
-blasted/primed and painted (black) crankshaft sprocket and power steering sprocket
I also have all accessories for the shortblock as well. Including:
-blasted/primed/painted 1z/AHU accessory bracket with good tensioner assembly (bracket is painted in cast aluminum)
-blasted/primed/painted 1z/AHU oil filter flange and stock sandwich
-water pump (complete and used with less than 2k on it)
New parts I have sitting to go on the motor for it's finished build include:
-Complete head set with head gasket (2 notch, plus valve cover gasket set, valve stems seals, cam seals, etc. etc.)
-Complete OEM timing belt set (Conti  timing belt, OEM tensioner, Conti serp accessory belt and power steering belts....ALL NEW)
Drivetrain wise:
- 1 120k CTN TDI 02j tranny in good order
- 1 SACHS VR6 clutch kit with less than 2k on it
May also consider selling:
- Holset HX25 turbocharger that I was going to run on the b3 version. Very close in size to my Merc turbo that I'm running on the MK1 on the cold side, but flow MUCH better than a T3 and this baby has the nice and small holset 6cm housing on the hot side (its a T25 flange for the inlet)
To give you an idea...
The compressor wheel on the HX25 is slightly larger than the GT20 Garretts but according to Holset it flows around 0.22kg/s or 30lb/min. Not bad at all. This will be a nice breathing little spool monster :) which was the idea for the b3's build since I was going for a blend of power, performance and economy instead of just all out power.
Also have:
- Stock IDI TD exhaust manifold
- ATP backset "t3" 8v manifold (same thing I have on my Mk1 mTDI
Hmm...maybe more to come. Its a feeler, looking for interest while I get bearings on prices. Lowballers need not inquire.
Joe
1972 VW Westfalia
Reply #1February 18, 2009, 08:50:28 pm
foxracer1
  • 991
« Reply #1 on: February 18, 2009, 08:50:28 pm »
Interested in the holset and the aftermarket t3 manifold.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #2February 20, 2009, 04:13:07 pm
RabbitGTDguy
  • 1274
« Reply #2 on: February 20, 2009, 04:13:07 pm »
foxracer 1...sent you a PM I believe.
Sorry guys...didn't get to pics today. Had to get the new tranportation in order and such.
Tomorrow...
Joe
1972 VW Westfalia
Reply #3February 20, 2009, 04:44:47 pm
foxracer1
  • 991
« Reply #3 on: February 20, 2009, 04:44:47 pm »
I got it. Gotta think about my options thanks.
91 S10 305 TPI T56
Reply #4February 20, 2009, 06:13:01 pm
« Reply #4 on: February 20, 2009, 06:13:01 pm »
Hey Joe, how much are you thinking for the gearbox?
Reply #5February 20, 2009, 06:48:56 pm
« Reply #5 on: February 20, 2009, 06:48:56 pm »
for anyone who cares, the CTN trans has some rediculously tall gearing...
final          1st.           2nd.          3rd           4th           5th
3.157   3.778   2.118   1.360   1.029   0.755
almost 60 mph (100km/h) at 2000 rpm!!!!  :shock: i'm also interested in the price
Reply #6February 20, 2009, 06:50:23 pm
« Reply #6 on: February 20, 2009, 06:50:23 pm »
Yeah Giles has one in his car. It's crazy low. I want to try it on my NA :D
Reply #7February 22, 2009, 06:45:42 pm
RabbitGTDguy
  • 1274
« Reply #7 on: February 22, 2009, 06:45:42 pm »
Sent PM's to you both...still didn't get to the pics today. Ended up working on finishing a few things up on the new ride (which I need to make a post about) and trying to track down upper spring caps for my brothers MK3. No luck on that...
and doh...have to go back to school tomorrow! Winter break went way too fast! Too much going on. Will try again tomorrow for pics...
1972 VW Westfalia
Reply #8March 08, 2009, 06:49:03 pm
RabbitGTDguy
  • 1274
« Reply #8 on: March 08, 2009, 06:49:03 pm »
Going to get to this tomorrow guys. Seems like I'm swamped during the week and the last few weekends I seem to be working on everyone else's cars besides my own.
Will hopefully have time to spread out the parts, take pics, etc. etc. tomorrow and post with prices.
Just to throw it out there. There is something I would entertain "getting" rid of all of this for and straight trading...
Since the new ride is a 02 225Q TT Roadster...I have toyed with the idea of in the next few years doing a TDI swap to it. Of course, the 1z/AHU motor just wouldn't fit the bill quite right and this time around...dare I say...I may go the electronics route and I've been thinking about using a PD motor or waiting for a CR motor to be wrecked, etc.
If a PD motor that was in good condition, was complete with wiring, etc. found its way in trade for this completely rebuilt, overbored, etc. unit...I'd entertain that. I'd work with a PD 110 or the like. Its a few years down the road anyways (concentration is now on the mTDI Mk1, doing its body work and continuing upgrades) but it will be that much "less" I have to find in those few years down the road and I can start working towards it now. Just a thought. Otherwise, it'll all be for sale here...
Not particularly interested in a ALH motor...
Joe
1972 VW Westfalia
