Author Topic: ~help me find a quick spooling 200hp turbo!~  (Read 4737 times)
February 17, 2009, 05:45:36 pm
53 willys
« on: February 17, 2009, 05:45:36 pm »
just like the title says....I want a quick spooling turbo with a 200hp rating(give or take) I would go BB if there are some good suggestion?
I'm not very good at specing out turbos...
I want good usable power....my k26 is a little slow and laggy...I feel I could run something close in size to the K26 but go ball bearing so I can get a faster spool up?
thoughts?
suggestions??
opinions??
Reply #1February 17, 2009, 06:13:50 pm
hamradio
  • 282
« Reply #1 on: February 17, 2009, 06:13:50 pm »
Maybe look into a saab 9000 mistu TD04?  It's pretty quick spooling on the gasser...when the boost comes on (which is pretty low and quickly), it hits and pulls like crazy until the rev limiter.
I think it's good to 25 psi or so...I think if one wants to go higher, I think a larger compressor housing can be added.  Also available fairly cheap.
Another option would be holsets.  I think there are some smaller holsets out there that would work...otherwise, I think one can get reasonably small exhaust sides for hx30's?  Maybe an hx30 with smaller hot side *might* be small enough for a diesel?
A saab friend of mine is doing 426whp with a hx30. :)
Reply #2February 17, 2009, 07:10:16 pm
rallydiesel
  • 1880
« Reply #2 on: February 17, 2009, 07:10:16 pm »
Maybe I'm just clueless but I don't think you will find anything unless you go with a big VNT, like a 22 or bigger.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #3February 17, 2009, 10:37:21 pm
AudiVWguy
« Reply #3 on: February 17, 2009, 10:37:21 pm »
Take a look at the IHI Turbos. They are ball bearing. I have a VF 14 soon to be installed, but would consider a VF 22. Or maybe one of their other bb turbos.
http://www.scoobytuner.com/products/?vApplicationID=3&sfID1=4&sfID2=40&productID=15
Cheers,
-JB
Reply #4February 18, 2009, 12:46:40 am
  • 3468
    • McScrubbins Body Wash
« Reply #4 on: February 18, 2009, 12:46:40 am »
i agree with the VNT comment. A turbo that is quick spooling and makes LOTS of boost (to support 200hp on a 1.9l engine? or 1.6... ) would have to be made surely by the gods.
Or have some sort of variable nozzle turbine... if only such technology existed! I'd go with a big freakin VNT.
ps. sweet jesus new turbos are pricey!
Reply #5February 18, 2009, 01:49:44 am
TurboJ
  • 661
« Reply #5 on: February 18, 2009, 01:49:44 am »
Holset HX27 or Schwitzer S1 / S1BG.
Many different variants, many of which support over 200 hp on a diesel engine.
Jetta II 1.6 TD 'Project 200'
Reply #6February 18, 2009, 06:19:41 am
53 willys
« Reply #6 on: February 18, 2009, 06:19:41 am »
Quote from: "rallydiesel"
yeah the VNT20 is good for around 180hp...witch is nice...but all the linkage and BS makes it less desirable to me...plus just plain locating a VNT turbo is not an easy task...
that's why I'm thinking a good Ball bearing turbo will be a my best bet..
Reply #7February 18, 2009, 06:24:15 am
53 willys
« Reply #7 on: February 18, 2009, 06:24:15 am »
thanks for all the help guys!!
I'm gonna wait and see what turbonetics has for my app...I sent them my build sheet on Monday.
their turbos are probably about the same price as the other I have seen listed...maybe even less.
I'm a turbonetics dealer so I should be able to get a pretty good pice on their ceramic BB turbo..
in the mean time I think I will look at the specs on the holset and schwitzer turbos...
thanks for all the suggestion!!
I know every body probably wants a 200hp quick spooling turbo for our cars!!!
maybe I am dreaming???
